Homework Help: Equations of Motion & Gravity
  • Thread starter Thread starter GraduateStillLearning021
    Homework
The discussion revolves around equations of motion and gravity, specifically focusing on calculating average and instantaneous velocities in the context of a particle's motion and a freely falling object. The original poster presents a series of problems related to these concepts.
  • Participants inquire about the meaning of units and clarify the notation used. There are discussions about the differences between average and instantaneous velocity, as well as the mathematical techniques required to calculate average velocity. Some participants encourage the original poster to think about relevant equations and strategies for approaching the problems.
The conversation is ongoing, with participants providing hints and encouraging the original poster to engage with the problems. There is a focus on understanding the concepts rather than providing direct answers, and multiple interpretations of the problems are being explored.
Participants note the importance of understanding definitions and the need for the original poster to attempt the problems before seeking help. There is a recognition of the homework context and the expectation for the original poster to contribute to the discussion.
I need help on these problems. Thank You.
1. A particle moves according to the equation
x = (10 m=s*s) t*t where x is in meters and t is
in seconds.
a. Find the average velocity for the time in-
terval from t1 = 2:38 s to t2 = 3:36 s. Answer
in units of m=s.
b.Find the average velocity for the time interval
from t1 = 2:38 s to t3 = 2:48 s. Answer in
units of m=s.
2. Consider the acceleration of gravity to be
10 m/s*s :
a. What is the magnitude of the instantaneous
velocity (speed) of a freely falling object 38 s
after it is released from a position of rest?
Answer in units of m/s.
b. What is its average speed during this 38 s
interval? Answer in units of m/s.
c. How far will it fall during this time? Answer
in units of m.
What do you mean by "m=s"? Do you mean m/s?
What have you done on these problems? Even if you've gotten barely anywhere, it's still better than nothing. (It's homework help, not homework answerbook)
yes i mean m/s.
I just need to know how to start them not the answers.
Surely you've had an idea? Thought about equations that might be useful? Thought about similar problems you could solve? Thought about what you can figure out, even if it's not what the problem is asking for? Thought about what information would let you answer the problem, even if you don't know how to get that information? Or even just substituted in the definition of a term?
Many of these are applicable to nearly every problem you will face -- so if you get in the habit of thinking about them, you will always be able to start a problem!
Yeah, like what is the difference between "average" and "instantaneous" velocity? What basic mathematical technique do you use to calculate an average?
Another hint, in case this part is giving you trouble:
When they say the magnitude, they mean the overall positive value in whatever direction the velocity is.
For example, if we're working in two dimensions and something has an x-velocity of 2, and a y-velocity of 3, the velocity is pointing diagonally "up" in an x-y graph. The magnitude of the velocity would be the length of the line you graph from the origin to the point (2,3).
22 + 32 = v2
v = sqrt(13).
What about in one dimension, as with your problem? Well, since there's only a velocity component in one direction, the magnitude is the absolute value of that component. So if you have only a y-velocity, as you will in this problem, it will be negative since the object is falling. But the magnitude will be positive, because there is no such thing as a negative length.
Average velocity deals with time intervals while instantaneous velocity deals with time instants.
Like average velocity = displacement in the time interval/time interval
instantaneous velocity = velocity at that instant, orthe velocity at which the particle would continue to move if the particle acceleration is put to 0 at that point.
I cannot do further help when you are not doing just by not posting the copy of your argument of the solutions and when one of the mentors are refusin to help you? I cannot help you neglecting Hurkyl advice.
I'm not refusing to help -- my goal is to respond to this problem in a way that helps the OP solve the next problem! (IMHO that's what this forum is all about) So, I'm trying to instill into the OP the notion that he should be trying these basic solving strategies when he doesn't know what to do.
If he does some of these basic strategies, and is still stuck, I would help him along further!
  • · Replies 30 ·
