Can you unscramble a scrambled egg?
The discussion revolves around the implications and interpretations of the Stern-Gerlach (SG) experiment, particularly in the context of applying a uniform magnetic field and the effects on spin states of particles. Participants explore theoretical scenarios, experimental setups, and the nature of quantum superposition and measurement.
  • Some participants propose that in a SG experiment with a uniform magnetic field, the output would not allow for distinguishing between individual atoms since there would be no vertical deflection, leading to a 50-50 mixture of states.
  • Others question whether the reasoning about the input and output states is correct, particularly regarding the nature of polarization and superposition.
  • A participant discusses the probability of measuring spin states at different orientations and suggests that splitting and recombining beams does not restore the original state but rather scrambles it.
  • Another participant introduces an analogy using polarizing filters to illustrate how combining beams can lead to unexpected results, suggesting that similar effects might occur in quantum systems.
  • There is mention of maintaining coherence in the beams to potentially recover the original state when recombined through a reversed SG magnet, highlighting the complexity of quantum measurements.
Participants express differing views on the outcomes of the SG experiment with a uniform magnetic field, the implications of beam splitting and recombining, and the nature of quantum states. No consensus is reached on these points.
Participants express uncertainty regarding the definitions of states and the conditions under which measurements are made, as well as the implications of coherence in quantum systems. Some assumptions about the nature of polarization and measurement are not fully explored.
Swamp Thing
Insights Author
Here is a fascinating article about the story of the landmark SG Experiment.
http://www.physicstoday.org/vol-56/iss-12/p53.html
There are some interesting twists to the tale, but I won't spoil them for you.
Some contemporary reactions to the results:-
http://www.physicstoday.org/vol-56/iss-12/captions/p53box1.html
Cheers,
S.T.
Question about SGE
What if we do a S-G experiment with a uniform magnetic field?
Each atom will still have to "decide" to point up or down, only we won't be able to tell them apart at the output of the apparatus because there will be no vertical deflection. Now, is this not a different situation from the input beam? At the input, (if I understand correctly) each atom is essentially "unpolarized" i.e. in a 50-50 superposition of both states. At the output, we have a 50-50 mixture where each individual atom is definitely "up" or "down".
My questions:
(a)is the above reasoning correct
(b) if so, is there an experiment that we can do to distinguish a beam that has been "combed out" by a uniform magnetic field, from a beam that has not passed through any field.
My questions:
I'm not a QM guru, so this won't be very specific:
Let's say we have a beam of electrons that's been polarized s.t. all spins are pointing up at orientation 0. Then if we slap a detector at an angle of θ to 0, then the probability of getting an electron with spin up orientation θ is cos(θ/2)2.
The probability for the other orientation from the 'combed pair' is cos((π-θ)/2)2=sin(θ/2)2
So, along any orientation, you would still get a 50-50 distribution of spins since you get .5*(sin2+cos2) probability of spin up.
So the splitting and recombining does not unscramble the electrons. In fact it scrambles them. You can do the following:
Let's say we've got a beam of electrons that is all spin-up in orientation 0. Now, if we split it into beams along orienation π/4, and then recombine it, we will get a beam with a 50-50 orientation split along spin orientation 0.
Oh, there's a nice easy experiment for you to check this.
It takes 3 polarizing filters and a light source.
Take the two polarizing filters, and line them up so their polarization is perpendicular. You should get almost no light coming through.
Now, if you put the third filter between them, you'll get *more* light coming through from before.
Analagous experiments are , I believe, possible with birefringent materials such as calcite, which can act as a beam splitters instead of eliminating a particular polarization.
I'm not exactly sure what you are saying, but you can certainly recombine the exit beams of a SG magnet by putting them through a second (reversed) SG. If you can maintain the coherence of the beams, you will not be able to distinguish the final beam from the original: it will be in its original pure state. That's (part of) what's weird about this stuff.
