Thread Closed
Discretization
Share Thread
Feb8-06, 12:27 PM   #1
Discretization
If I have a logged temperature change over time which makes up a plottet graph. I denote this change
[tex]
{{dT} \over {dt}}
[/tex]
People have told me this can be solved using discretization, but I have no idea what that is. Apparently it is something like this:
[tex]
{{T_1 - T_2 } \over {\Delta t}}
[/tex]
but I don't really know what it means. Also, isn't a differential equation supposed to end up as a function of some variable? If so, how can an approximation like this wind up as one? Could someone explain it to me? Thx
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Feb8-06, 01:12 PM   #2
Quote by TSN79
[tex]
{{dT} \over {dt}}
[/tex]
[tex]
[/tex]
Say you have logged time T = [T1,T2,T3....TN] over time values t = [t1,t2,t3,...tN]
now, if you do a plot of T vs t, you would get a curve. If all goes well, your plot may represent a function, say like newton's law of cooling ..some exponential form may be available. Now, a continuous function like exp is continuously differentiable. Hence, assume you got a solution
T =f(t),
at any time t, you can get dT/dt leading to
dT/dt = f'(t) evaluated at some time t.
Now, this is straightforward.
Also, thiink abt a curve made up of discrete points.
So to get a change or derivative (the slope), we can also do
dT/dt at t1 = (T2-T1)(t2-t1) like forward differenced
or dT/dt at t1 = (T1-T2)/(t1-t2) backward differenced.
However, since these are first order approximations of the original functions, f(t) , your solution of evaluating dT/dt is first order accurate.
Higher order can be achieved by taking more grid points. Look at finite difference approximations.
the smaller the difference between t1 and t2, the better approximation of your time derivative.
Thread Closed
Similar discussions for: Discretization
Thread Forum Replies
Discretization of the Poisson Equation across Heterointerface Advanced Physics Homework 1
