Calculating Torque for an Auger-Powered Ball Pushing Application
  • Thread starter Thread starter ZIG
    Torque
The discussion focuses on calculating the torque required for a DC motor to power an auger that pushes balls weighing 0.5 lbs with an applied pressure of 2.5 lbs. The motor must operate at a speed of 1500-1800 RPM. Participants are encouraged to share specific formulas for torque calculation relevant to this application, emphasizing the need for detailed explanations of the formulas used.
  • Understanding of torque calculation principles
  • Familiarity with DC motor specifications and performance
  • Knowledge of auger mechanics and their operational parameters
  • Basic physics concepts related to force and motion
  • Research torque calculation formulas for rotating shafts
  • Learn about DC motor torque ratings and their implications
  • Explore the mechanics of augers and their efficiency in material movement
  • Investigate the relationship between RPM and torque in motor applications
Engineers, hobbyists, and developers involved in mechanical design, particularly those working with auger systems and DC motor applications.
ZIG
I am developing an application with an auger (a type of drill bit ) in which this auger will be pushing balls up a tube. The weight of the balls equals about .5 lbs but I would like to have 2.5lbs of pressure applied to them. The auger will be powered by a DC motor and I need to figure out the torque rating needed for this motor to push this kind of weight in inch pounds. The motor needs to spin at 1500-1800 RPM if that is helpful. Does anyone have a formula or formulas for calculating something like this? Attached is a basic drawing of the auger specs and what it looks like. If the image does not show, it is located at www.develonet.com/auger1.GIF[/URL]
Please detail your formula if you have one.
Thanks a ton!
Please do not post your question in more than one forum at a time.
- Warren
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 19 ·
