- 2,284
- 3
"At the end of the day, the same criticism applies to any purely physical account of consciousness. For any physical process we specify there will be an unanswered question: Why should this process give rise to experience? Given any such process, it is conceptually coherent that it could be instantiated in the absence of experience. It follows that no mere account of the physical process will tell us why experience arises. The emergence of experience goes beyond what can be derived from physical theory.
Purely physical explanation is well-suited to the explanation of physical structures, explaining macroscopic structures in terms of detailed microstructural constituents; and it provides a satisfying explanation of the performance of functions, accounting for these functions in terms of the physical mechanisms that perform them. This is because a physical account can entail the facts about structures and functions: once the internal details of the physical account are given, the structural and functional properties fall out as an automatic consequence. But the structure and dynamics of physical processes yield only more structure and dynamics, so structures and functions are all we can expect these processes to explain. The facts about experience cannot be an automatic consequence of any physical account, as it is conceptually coherent that any given process could exist without experience. Experience may arise from the physical, but it is not entailed by the physical.
The moral of all this is that you can't explain conscious experience on the cheap. It is a remarkable fact that reductive methods - methods that explain a high-level phenomenon wholly in terms of more basic physical processes - work well in so many domains. In a sense, one can explain most biological and cognitive phenomena on the cheap, in that these phenomena are seen as automatic consequences of more fundamental processes. It would be wonderful if reductive methods could explain experience, too; I hoped for a long time that they might. Unfortunately, there are systematic reasons why these methods must fail. Reductive methods are successful in most domains because what needs explaining in those domains are structures and functions, and these are the kind of thing that a physical account can entail. When it comes to a problem over and above the explanation of structures and functions, these methods are impotent.
This might seem reminiscent of the vitalist claim that no physical account could explain life, but the cases are disanalogous. What drove vitalist skepticism was doubt about whether physical mechanisms could perform the many remarkable functions associated with life, such as complex adaptive behavior and reproduction. The conceptual claim that explanation of functions is what is needed was implicitly accepted, but lacking detailed knowledge of biochemical mechanisms, vitalists doubted whether any physical process could do the job and put forward the hypothesis of the vital spirit as an alternative explanation. Once it turned out that physical processes could perform the relevant functions, vitalist doubts melted away.
With experience, on the other hand, physical explanation of the functions is not in question. The key is instead the conceptual point that the explanation of functions does not suffice for the explanation of experience. This basic conceptual point is not something that further neuroscientific investigation will affect. In a similar way, experience is disanalogous to the élan vital. The vital spirit was put forward as an explanatory posit, in order to explain the relevant functions, and could therefore be discarded when those functions were explained without it. Experience is not an explanatory posit but an explanandum in its own right, and so is not a candidate for this sort of elimination.
It is tempting to note that all sorts of puzzling phenomena have eventually turned out to be explainable in physical terms. But each of these were problems about the observable behavior of physical objects, coming down to problems in the explanation of structures and functions. Because of this, these phenomena have always been the kind of thing that a physical account might explain, even if at some points there have been good reasons to suspect that no such explanation would be forthcoming. The tempting induction from these cases fails in the case of consciousness, which is not a problem about physical structures and functions. The problem of consciousness is puzzling in an entirely different way. An analysis of the problem shows us that conscious experience is just not the kind of thing that a wholly reductive account could succeed in explaining."
- excerpted from "http://www.u.arizona.edu/~chalmers/papers/facing.html ," by David Chalmers
