Mechanics difficulties - acceleration
The discussion revolves around a mechanics problem involving the calculation of time for an object dropped from a height of 100 feet, with a focus on acceleration due to gravity and the appropriate kinematic equations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to use a kinematic equation but questions its validity after obtaining an incorrect result. Participants suggest alternative formulas and emphasize the importance of consistent sign conventions in calculations.
Participants are actively engaging with the problem, offering guidance on formulas and clarifying concepts. There is a focus on ensuring the original poster understands the implications of sign conventions and unit conversions, though no consensus has been reached on the correct approach yet.
There is a mention of the need to convert feet to meters for consistency in calculations, and the original poster expresses uncertainty regarding the application of the formulas discussed.
Micah18
Hey, I came across this site on one of my many google searchs on my quest to solve this problem, and was hoping someone could help me out.
The following word problem is the one I am trying to solve:
An object is dropped from 100 feet up. Negating wind resistance, calculate the time it took for the object to hit the ground.
What I know is as follows:
x = 100 feet
a = -9.8m/s^2
v_o = 0m/s.
The formula I have tried is 100 = v_o + 0.5(-9.8t). Obviously, it's the wrong formula as I get the wrong answer everytime (the answer I get is 6.1 or 6.2 seconds, can't remember at the moment). I chose that formula because it doesn't require the final velocity at the bottom. I suspect I need to find the final velocity, but I don't know how to go about that.
Any help would be appreciated!
BTW, I registered earlier with the name "Micah," but it never sent me an activation e-mail. Not sure if that's a problem with my e-mail provider (AOL, yay) or the forum. If possible, I'd rather use "Micah" rather than Micah18, so if the admin could resend the activation e-mail (if that is even possible) that would be nice.
Try this formula: [tex]x=x_0+v_0t+\frac{1}{2}at^2[/tex]
Be sure to use a consistent sign convention.
I will try that tomorrow.
Sorry if I am a bit slow, but what do you mean by consistent sign convention?
Make sure that either + always means upwards or that + always means downwards.
Ah yes, will do.
In general, I always find it useful that when g = 9.8m/s^2, and there is no air etc and you just drop something, you can just use.
[tex]\sqrt{\frac{h}{4.9}}[/tex]
The derivation is pretty simple, but it is a nifty reference when you are in a time bind.
It goes without saying that u must change feet into metres (something u didnt do when posting ure first equation in ure first post)
