Thread Closed
Center of pressure problem
Share Thread Thread Tools
Feb12-06, 11:16 AM   #1
I have some intro aeronautical class homework problem that is giving me difficulty.
I need to find the center of pressure for the upper surface of an airfoil in terms of percent chord from the leading edge. I know that the chord lenth is 1m. The pressure from the top surface of the airfoil starting at the chord is 3N/m. The pressure from the bottom surface of the airfoil starting at the chord is 1N/m. There is no angle of attack and I do not know the velocity of the incoming air.
Do I need to use the equation Cp=Pt-P/1/2pv^2 ?
I can't understand how to use this equation in the context of this problem.
Any help pointing me in the right direction would be appreciated
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Feb12-06, 01:29 PM   #2
Admin
Center of pressure (cop). The point at which the aerodynamic lift on a rocket is centered. (from http://www.daviddarling.info/encyclo..._pressure.html)
Perhaps try this approach as applied to the foil.
http://www.grc.nasa.gov/WWW/K-12/airplane/rktcp.html
Feb12-06, 11:20 PM   #3
I've looked at methods similiar to what was on that page, however I don't think I have enough information from that problem to use this method.
Do I have to know the velocity of the incoming flow in order to determine the center of pressure? I have a sort of triangle made for determining the center of the triangle. However, I only know the length of one side-the base is 1m. I know the pressure acting on another side, but that's all.
Feb13-06, 12:50 AM   #4
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Can you give the exact wording of the problem?
Feb13-06, 08:16 AM   #5
"Find the center of pressure for the upper surface of the airfoil (in terms of %chord from the leading edge)."
I was trying to get the picture from the problem posted up here, but I haven't been able to so far.
Thread Closed
Thread Tools
Similar Threads for: Center of pressure problem
Thread Forum Replies
Pressure at center of planet General Astronomy 7
Center of Gravity Problem Introductory Physics Homework 1
Pressure at center of earth (or any planet) Introductory Physics Homework 0
need help with center of mass problem Introductory Physics Homework 1
Center of Mass Problem Introductory Physics Homework 7
