Find the final percentage of light exiting the last polizer
  • Context: Undergrad
  • Thread starter Thread starter matrix_204
    Final Light
The discussion focuses on calculating the final percentage of light exiting the last polarizer when three polarizers are stacked with specific angles. The method involves computing the output of the first pair of polarizers and using that result as the input for the third polarizer. Notably, when two polarizers are oriented at 90 degrees, they block nearly all light, but introducing a third polarizer at a 45-degree angle between them allows some light to pass through, demonstrating the twisting effect of light in this configuration.
  • Understanding of polarizer physics and light behavior
  • Familiarity with Malus's Law for calculating transmitted light intensity
  • Basic knowledge of angles and trigonometry
  • Experience with optical systems and their configurations
  • Study Malus's Law in detail to understand light transmission through polarizers
  • Explore the effects of varying angles between multiple polarizers
  • Research optical systems that utilize multiple polarizers for light manipulation
  • Experiment with simulations of light passing through polarizers at different angles
Students and professionals in physics, optical engineering, and anyone interested in the principles of light behavior through polarizers.
matrix_204
I was having some difficulty in solving problems, where they ask to find the final percentage of light exiting the last polizer, when three polirizers are placed on top of each other. With a certain angle between the first two polirizers and an angle between the first and the third polirizer.
please help me asap, thnx
Science news on Phys.org
It is no different then when 2 are present compute the output of the first pair, then use that as the input of the third. You will see some seemly strange results. If you have 2 filters at 90 deg they will block all (most) light. If you insert a 3rd filter BETWEEN the first 2 at 45 (or just something other then 90deg) you will suddenly get output from the last filter.
Sort of like the light gets twisted passing through the system.
  • · Replies 24 ·
  • · Replies 34 ·
  • · Replies 32 ·
