Limits with trig functions manipulations
The discussion revolves around evaluating limits involving trigonometric functions, specifically focusing on the limit as \( t \) approaches 0 for the expression \( \frac{\tan 6t}{\sin 2t} \). Participants are exploring various manipulations and identities to simplify the expression and apply known limit results.
  • Participants discuss transforming the limit expression into forms that utilize the known limit \( \lim_{x\rightarrow 0} \frac{\sin x}{x} = 1 \). There are attempts to apply trigonometric identities and substitutions to facilitate this process. Questions arise about the validity of assumptions regarding limits and the application of L'Hospital's Rule.
The conversation is active, with participants sharing their progress and insights. Some have made advancements in their understanding of the limit, while others express uncertainty about specific steps or concepts, such as the use of the squeeze theorem and the conditions under which certain limits hold. There is no explicit consensus on the final outcome, but several productive lines of reasoning are being explored.
Participants are navigating through concepts typically covered in introductory calculus, with some expressing uncertainty about the level of rigor expected for proofs and limit evaluations. There is mention of homework constraints and the need to adhere to specific problem-solving methods as outlined in their coursework.
Jeff Ford
I'm pretty useless at trig manipulations, but I'm trying to learn
According to my text, the key to limits with trig functions is to get them into this form
[tex]\lim_ {t\rightarrow 0} \frac{\sin x}{x} = 1[/tex]
I've been doing alright with that, but I'm stuck on this one
[tex]\lim_ {t\rightarrow 0} \frac{\tan 6t}{\sin 2t}[/tex]
I'm not sure what else to turn this into besides
[tex]\lim_ {t\rightarrow 0} \frac{\sin 6t}{\sin 2t \cos 6t}[/tex]
A poke in the right direction would be appreciated.
Thanks
Jeff
You could use the identity
[tex]tg2x=2tgx/(1-tg^2x)[/tex]
I tought I read in another thread that you teach a calculus class. Did I misread?
[tex]\lim_ {x\rightarrow 0} \frac{\sin x}{x} = 1[/tex]
[tex]\lim_ {x\rightarrow 0} \frac{\tan 6t}{\sin 2t}[/tex]
[tex]\lim_ {x\rightarrow 0} \frac{\sin 6t}{\sin 2t \cos 6t}[/tex]
Thanks
Jeff
Take a look at
[tex]\frac{n}{m}\frac{sin 6t}{nt}\frac{mt}{sin 2t}\frac{1}{cos 6t}[/tex]
I'll let you do the work of deciding how to choose n and m correctly.
I do not teach a calculus class, I take a calculus class :-p
Ok, I've made some progress
[tex]\lim_ {t\rightarrow 0} \frac{\sin 6t}{\sin 2t \cos 6t} (\frac{12t}{12t}) = \lim_ {t\rightarrow 0} \frac{6}{2} (\frac{\sin 6t}{6t}) (\frac {2t}{\sin 2t}) (\frac{1}{\cos 6t})[/tex]
I know the limit here for each term except [tex](\frac {2t}{\sin 2t})[/tex]
Straight substitution leaves this undeffined. Is there a standard for working out limits in this form?
Is your limit [tex]x\rightarrow 0[/tex] or [tex]t\rightarrow 0[/tex]? Anyway, I seem to remember that even
[tex]\lim_{x\rightarrow 0} \frac{x}{\sin{x}}=1[/tex]
but I am far from certain.
It's [itex]t\rightarrow 0[/itex]. I've made the change in the earlier posts.
It would seem that if [tex]\lim_{x\rightarrow 0} \frac{\sin x}{x} = 1[/tex] then [tex]\lim_{x\rightarrow 0} \frac{x}{\sin x} = 1[/tex], but I'm wary of making that assumption. Can someone clarify if I am correct?
If so, the answer to my original question is 3, which matches up with the back of the text.
Thanks
Jeff
I seem to remember this being the case. However I was not certain so I did a quick check in Mathematica and it gives me the same answers. The question is; how reliable is Mathematica? :smile:
Thanks
Jeff
Do you agree that your wariness hinges upon the following:
Given that lim f =L (non-zero), then lim 1/f =1/L ?
What do you know about this statement?
It appears to be true. I can't think of a counter example.
That's not good enough! You should prove it!
Here's one way:
1. assume that the limit of f at x=0 is L (non-zero)
Since L is non-zero, there must be a non-zero neighbourhood about x=0 where f is always non-zero (otherwise, L could not be f's limit value at x=0, since at arbitrarily close points, there would be function values differing from L at least of magnitude L)
2. Regard the difference (within the domain existing by virtue of 1.):
[tex]|\frac{1}{f}-\frac{1}{L}|=\frac{1}{|f||L|}|f-L|[/tex]
try to concoct an epsilon-delta proof to show that the statement holds.
I'm still in Calc I and haven't done much more than the most basic epsilon-delta proofs. I'd love to learn how, but I'm uncertain as to where to begin.
Do I start with [tex]|\frac{1}{f}-\frac{1}{L}| < \epsilon[/tex] and [tex]\frac{1}{|f||L|}|f-L| <\epsilon[/tex] and try to find [tex]\delta > |x|[/tex] that works for both cases?
The first thing to remember about the epsilon-delta business is not to bother overmuch about the epsilon!
What IS in general important, is to bound your expression with a function of delta that is easily seen to go to zero as delta goes to zero.
Now, in this case there are two salient features:
1. We need to estimate the |f| in the denominator in a clever manner.
2. We have the difference |f-L| to take care of.
1. We want to find an upper bound for [itex]\frac{1}{|f||L|}|f-L|[/itex]
Hence, we should first find a LOWER bound for |f|, since it appears in the denominator.
Since we know that the limit of f is L, there will exist a [itex]\delta_{1}[/itex] so that for all x's inside that delta,[tex]|f|\geq\frac{|L|}{2}[/tex]
(the half is chosen for simplicity, the validity of the inequality is straightforward to see).
2. Since f goes to L, then for any [itex]\epsilon[/tex] there will exist a [itex]\delta_{2}[/itex] so that [itex]|f-L|\leq\frac{L^{2}\epsilon}{2}[/tex]<br /> (This particular choice is just cosmetics, in order to end up with a nice expression.)<br /> <br /> 3. Thus, choosing [itex]\delta=minimum(\delta_{1},\delta_{2})[/itex]<br /> we get, for x's inside the delta-band:<br /> [tex]\frac{1}{|L||f|}|f-L|<\frac{2}{L^{2}}\frac{L^{2}\epsilon}{2}=\epsilon[/tex]<br /> Voila![/itex][/itex]
Clever logic. It took me awhile, but I think I understand what you did. Just for reference, is this something I should be learning at the Calc I level, or does this usually come up in something like an Analysis class?
Since you are in Calc 1 you can use L'Hospital's Rule to show that the limit exists and is also 1.
And how do you prove in the first place that we have:
[tex]\frac{d}{dx}\sin(x)=\cos(x)[/tex] ?
That's about a chapter ahead of where I am now. I read a few sections ahead of the class, but not quite that far.
Ah, I didn't realize you hadn't covered derivatives yet.
I can follow the proof of this one almost all the way to the end, staring from the limit definition of the derivative. I just get a little stuck at the last step. I can break it down to terms that are almost all defined when [itex]h = 0[/itex] but I get two terms in that step that are [tex]\lim_{h\rightarrow 0} \frac{\sin(h)}{h}[/tex]
I know this equals one, but I'm not sure how to prove this logically. The proof in my text is only done geometrically.
Without using derivatives, you can show this since for small values of x (we're letting x going to 0), we have that:
[tex] \begin{array}{l}<br /> \sin x \le x \le \tan x \\ <br /> \frac{{\sin x}}{{\sin x}} \le \frac{x}{{\sin x}} \le \frac{{\tan x}}{{\sin x}} \\ <br /> 1 \le \frac{x}{{\sin x}} \le \frac{1}{{\cos x}} \\ <br /> \end{array}[/tex]
And since [itex]\mathop {\lim }\limits_{x \to 0} \frac{1}{{\cos x}} = 1[/itex], we've now 'squeezed' our function between two which have limit 1.
Ah, the squeeze theorem. I hadn't had a chance to make use of that yet. Thanks!
You're welcome :smile:
Another, geometric "proof" is the following:
1. Draw a unit circle
2. Draw a line through the centre with angle x (in radians!) to another line through the centre (say, the horizontal).
3. Consider the areas of the 3 figures:
a) the triangle with hypotenuse 1, base cos(x) and height sin(x)
(area: 1/2*sin(x)cos(x))
b) the circle sector indicated, area x/2
c) the right-angled triangle with base 1 and height tan(x)
area: tan(x)/2
Evidently, we have a<b<c, which can be rewritten as,by dividing throughout with sin(x)/2:
[tex]cos(x)<\frac{x}{\sin(x)}<\frac{1}{\cos(x)}[/tex]
the value of the ratio is squeezed into 1 as x goes to zero..
The explanation I got from my instructor last night was
[tex]\lim_{x\rightarrow 0} \frac{f(x)}{g(x)} = \frac{\lim_{x\rightarrow 0} f(x)}{\lim_{x\rightarrow 0} g(x)}[/tex]
Therefore
[tex]\lim_{x\rightarrow 0} \frac{x}{\sin(x)} = \frac{\lim_{x\rightarrow 0} 1}{\lim_{x\rightarrow 0} \frac{\sin(x)}{x}}[/tex]
Note that this only holds if both limits in numerator and denumerator exist.
True, I should have made that clarification. Thanks.
  • · Replies 18 ·
  • · Replies 40 ·
