- 19,917
- 10,945
We would like you input on which skin you'd like to see as the default.
Doc Al said:Other than appearance, what are differences in the two skins? (Is the functionality identical?)
I'm voting with Doc Al on all of the above points!Doc Al said:If it's faster, and will help get back the preview window (), then Prime's my choice--all things being equal (see below). I'll take function over form any day. (It's a bit cleaner looking, anyway.)
I don't like the main page sidebar, but I almost never use the mainpage anyway. But without the "forum jump" feature that used to be at the bottom, I'm forced to use the mainpage. If that feature's not coming back, then I'll stick to Nexus.
If that sidebar is removed, Prime wins for me.
Greg Bernhardt said:At 1024x768 and above resolution the sidebar should not feel cramped imo. If you are using a lower resolution I would suggested buying a monitor made within the last 10 years and get with the times![]()
1024X768 is the highest resolution...it's only a 12" laptop, not one of those monstrous 15" ones some people get. The problem is the table with the forum index gets compressed, but not the sidebar, so on the smaller monitor, the sidebar takes up a disproportionate amount of the main page. It looks sort of like 2/3 index and 1/3 sidebar. On the 17" monitor at home, it looks more like 4/5 index and 1/5 sidebar, which is more reasonable. I'd really rather ditch the sidebar than view such a squished index. And, no, I'm not going to get a different laptop or monitor just to view PF.Greg Bernhardt said:At 1024x768 and above resolution the sidebar should not feel cramped imo. If you are using a lower resolution I would suggested buying a monitor made within the last 10 years and get with the times
Moonbear what res are you running on your laptop? I currently run at 1920x1200
