What is the correct method for combining systematic errors in measurements?
  • Context: Graduate
  • Thread starter Thread starter ahrkron
    Measurements
The discussion revolves around the correct method for combining systematic errors in measurements, particularly in the context of two measurements of the same quantity, each with statistical and systematic errors. Participants explore theoretical approaches and practical implications of error combination.
  • One participant presents two measurements with defined statistical and systematic errors and asks how to combine these systematic errors.
  • Another participant suggests that systematic errors may be negligible compared to larger statistical errors, potentially folding them into the overall measurement uncertainty.
  • A different participant proposes a mathematical approach to combine errors, indicating a formula for calculating total errors based on statistical and systematic contributions.
  • Concerns are raised about the nature of systematic errors, questioning whether they represent consistent measurement errors or other factors.
  • One participant shares experiences from Fourier transform spectroscopy, noting that systematic errors can be significantly larger than statistical errors, leading to inconsistencies across different labs.
  • Another participant critiques a proposed formula for combining systematic errors, pointing out that it yields a dimensionless result and suggests that it may require adjustment based on the final value of the measurement.
  • A later reply references a textbook that states systematic and statistical errors should be treated independently, proposing a method for combining them that aligns with this perspective.
Participants express differing views on the significance and treatment of systematic errors in relation to statistical errors. There is no consensus on a definitive method for combining these errors, and the discussion remains unresolved.
Some participants acknowledge limitations in their understanding and the absence of reference materials during the discussion. There are also unresolved questions regarding the definitions and implications of systematic errors.
ahrkron
Staff Emeritus
Say you have two measurements of the same quantity:
t = 500 +- 20 +- 3
t = 600 +- 90 +- 10
where the first error is statistical and the second is systematic.
What is the correct way of combining the systematic errors?
i.e., if I want to put both measurements together into
t = x +- dx1 +- dx2
How should I obtain dx2?
I assume that you Statistical error is a measurement average. It would seem to me that the systematic errors would be lost in the much larger measurement error, so in essence would be folded in with no effect.
I am open to disscussion.
Let [tex]\partial x_1,\partial x_2,\partial y_1,\partial y_1[/tex] denote the statistical and systematic errors in the variables [tex]x,y[/tex] respectively.
When one calculates [tex]T=x+y[/tex] I think the errors will be:
[tex]\partial T_1 = \sqrt{(\partial x_1)^2+(\partial y_1)^}[/tex]
and
[tex]\partial T_2 = \sqrt{\left(\frac{\partial x_2}{x}\right)^2+\left(\frac{\partial y_2}{y}\right)^2}[/tex]
However, I am doing this without a textbook so I hope I am remembering correctly... :wink:
Edit: TeX-error corrected.
If I were to combine the errors that is the most logical approach, still not clear to me that, that yields a meaningful number.
Perhaps I am mistaken in the nature of the statistical error.
What is the nature of the Systematic error? Is in a consistent measurement error or something else?
Thanks for the replies.
It is a measurement of the dispersion of the data you have. If the parent distribution is a gaussian, then the RMS of the data is a good estimator of the standard deviation.
The statistical error decreases as you get more data.
On the other hand, there are other things that affect your measurement do not depend (directly, at least) on the amount of data you have. Examples of these are the numbers you use as input to your calculations, or the decisions you make along the way between different (but reasonable) ways to perform the measurement. These are the systematic errors.
Not necessarily. Sometimes you may have a lot of data at your disposal, hence yielding a rather small statistical error, but there are various models for how to fit the data (say, with either an exponential or a polynomial background), and the choice may have a big effect on your final value (i.e., it may shift it by an amount much larger than the statistical error).
I agree. I used to do Fourier transform spectroscopy, and the statistical errors were miniscule. The systematic errors were about 1000 times as large for some data. We'd measure the index of refraction of a material, and get consistency for several different pieces out to 6 decimal places. Then we'd compare our numbers with other labs, measuring the same samples, and we'd have inconsistancies of almost 1%.
Njorl
Thanks, ... but we're missing something there, since [itex]T_2[\itex] comes out dimensionless. Maybe multiplying by the final value of T? but then both systematic errors have the same weight, regardless of their statistical significance... I'm not saying this is wrong, but it just seems odd (to me at least)...[/itex]
Thanks, ... but we're missing something there, since [itex]T_2[\itex] comes out dimensionless. Maybe multiplying by the final value of T? but then both systematic errors have the same weight, regardless of their statistical significance... I'm not saying this is wrong, but it just seems odd (to me at least)...[/itex][itex][/itex]
[itex] <br /> You must be right, my equation must be wrong as I could immediately have seen from the dimensions. <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":frown:" title="Frown :frown:" data-smilie="3"data-shortname=":frown:" /> Like I said, I did it without a textbook. I'll try to dig up my old textbooks over the weekend and see what they say.<br /> <br /> Stay tuned, more to come! <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" />[/itex]
OK, I checked the only book that I have on this (Squires - Practical Physics). He states that the two errors are independent and therefore they should be treated separately. This makes sense. As a result, he uses the same method for combining two errors under addition:
[tex]\partial T_i = \sqrt{(\partial x_i)^2+(\partial y_i)^2}[/tex]
regardless weather [tex]\partial T_i[/tex] refers to the statistical or the systematic error.
So, in your case
t = 500 +- 20 +- 3
t = 600 +- 90 +- 10
the result would be
[tex]550 \pm 92.2 \pm 10.4[/tex]
Hope this helps.
  • · Replies 21 ·
  • · Replies 72 ·
  • · Replies 22 ·
  • · Replies 26 ·
