What happens when two black holes collide?
The discussion centers on the phenomena associated with the collision of two black holes, exploring the dynamics of their interaction, potential outcomes, and the implications of their spins. The scope includes theoretical considerations and implications for gravitational wave detection.
  • One participant suggests that two black holes would typically enter a tight hyperbolic orbit unless they were to collide directly, which could lead to them fusing into a larger black hole.
  • Another participant notes that if the black holes were to pass closely, they might radiate significant gravitational energy and eventually merge due to energy loss from gravitational radiation.
  • It is proposed that the presence of a third body could influence the dynamics of the black holes' interaction, particularly in non-relativistic scenarios.
  • One participant raises a question about the effects of spinning black holes on the collision outcomes, seeking further information on their characteristics.
  • A later reply indicates that the collision of spinning black holes is an active research area with limited current understanding, suggesting that adding spin complicates the scenario significantly.
Participants express varying degrees of certainty regarding the outcomes of black hole collisions, with some aspects being more established than others. There is no consensus on the effects of spin or the specifics of the collision dynamics.
Participants acknowledge that the understanding of black hole collisions, particularly involving spinning black holes, is still developing, and many assumptions remain untested or unresolved.
This discussion may be of interest to those studying astrophysics, gravitational wave research, or the dynamics of black holes and their interactions.
varsha
i want to know what exactly happens when two black holes collide. in detail.
Astronomy news on Phys.org
Assuming no other material was present it is most likely that two black holes would swing a tight hyprbolic orbit around each other and go their way.
If they passed each other very closely it would be possible for there to be a significant radiation of gravitational energy for them to go into orbit around each other. For this to happen in non relatavistic circumstances this usually needs the gravitational influence of a third body or a physical collision. This orbit would gradually loose energy by gravitational radiation and the two holes would eventually fuse to make a single larger rotating black hole.
It is of course remotely possible if they were moving directly towards each other with no net angular momentum they would collide directly and instantly fuse to make a larger black hole.
Either way there is no particular reason for the radiation of anything other than gravitational energy (and of course the hawking radiation of the black holes themselves.
If there was other material present the signatures of the black holes accretion disks would be visible and mosulated by the orbits of the holes.
There is a link referred to elsewhere in this are which gives the gravitaitional wave signature of a pair of black holes in the final stages before they merge. This rising chirp of frequencies is expected to be one of the most detectable signals in the gravitiational wave environment and could be detected at vast distances.
what happens if two spinning black holes collide? will the effects be the same as u mentioned above? and can you tell me more about spinning black holes?
and oh, thanks for that info. i didn't know that last bit.
This is a very active research area, but only a few things are known even about collisions of nonrotating black holes (though this might be changing very soon). Adding spin goes beyond what anyone could tell you right now.
  • · Replies 40 ·
  • · Replies 17 ·
