Which Track Will Have the Greater Ball Speed?
The discussion revolves around a physics problem involving two tracks (A and B) along which identical balls are released from rest. Participants are exploring which ball will have the greater speed upon reaching the end of the tracks, considering factors such as energy conservation and potential differences.
  • Participants discuss the conservation of energy, questioning how potential energy changes relate to kinetic energy. Some raise concerns about the impact of friction and the differing lengths of the tracks on the outcome.
The discussion is active, with participants offering various perspectives on energy conservation and the role of friction. There is no explicit consensus on the outcome, as multiple interpretations are being explored.
Participants note the absence of a visual reference for the tracks and emphasize the need to consider friction in their analysis. The assumption that both tracks start and end at the same heights is also under discussion.
cutie05
Consider the identical balls released from rest on Tracks A and B as shown. When they reach the right ends of the tracks, which will have the greater speed?
Will The ball on track B will have the greater speed.
There is not enough information to decide.
Both will have the same speed.
The ball on track A will have the greater speed.
Tough to say, since the picture is awaiting approval. The general approach should use the idea that energy is conserved. Any loss of potential energy is compensated for by an increase in kinetic energy. Your change in potential energy is reflected in the change in height (PE = mgh). Your change in kinetic energy is reflected in the change in velocity (KE=1/2 mv^2). If you lose height, the velocity has to increase. If you gain height, the velocity has to decrease.
Since the track lengths are different, you have know about friction. Do you ignore it?
Well, since the tracks both start and end at the same heights, the speed must be the same if they both start at the same speed. Using the potential energy = mgh, and the mechanical energy formula K_f + U_f = K_i + U_i.
You need to know if the track has friction
