What Water Levels Produce Resonance Frequencies with a Tuning Fork?
  • Thread starter Thread starter dekoi
    Physics Resonance
The discussion focuses on determining the water levels that produce resonance frequencies with a tuning fork at 300 Hz placed atop a metal cylinder. The natural frequencies in an open-closed system are calculated using the formula f_n = nv/4L, where n represents the harmonic number. The first resonance frequency occurs at a water level of L_1 = 0.286 m. The subsequent resonance frequency can be calculated using the same formula, but the exact method for determining the second level is questioned.
  • Understanding of resonance frequencies in open-closed systems
  • Familiarity with the formula f_n = nv/4L
  • Basic knowledge of tuning forks and sound waves
  • Concept of beat frequency in acoustics
  • Research the calculation of higher harmonic frequencies in open-closed systems
  • Explore the relationship between water levels and sound resonance
  • Learn about beat frequencies and their applications in acoustics
  • Investigate the impact of flow rates on resonance in fluid dynamics
Students and professionals in physics, acoustics researchers, and anyone interested in the principles of sound resonance and fluid dynamics.
dekoi
There's a metal cylinder from which water is flowing out at a rate of 10^-6 m^3/s. A tuning fork of 300 Hz is placed on top of the cylinder. At what water levels will the first two resonance frequencies be heard?
It doesn't seem like a difficult problem, and it really isn't. I just can't seem to see it.
I don't think the flow rate has any signifiance in calculation; it's only useful to know that the water level is decreasing.
It's an open-closed system, so the natural frequencies are [tex]f_n = \frac{nv}{4L}[/tex] where n = 1, 3, 5, 7...
So in the first case, i think the first frequency heard would be 300 Hz. Hence, one can solve for [tex]L_1[/tex] to attain 0.286m. But how about for the next? Will it just be 3 times L_1 ? Or how do you solve for it otherwise?Thanks
Question 2: Is it logical to ask whether the beat frequency is e.g. +4 or -4? Afterall, [tex]f_{beat} = |f_2 - f_1|[/tex] so because of the absolute value,it is always +4.
Anyone?
