Calculating Time Dilation for Travel to Alpha Centauri
  • Context: Graduate
  • Thread starter Thread starter daenku32
    Alpha Alpha centauri
The discussion revolves around calculating time dilation for a hypothetical round trip to Alpha Centauri at 50% of the speed of light. Participants explore the implications of special relativity on time measurement from different reference frames, specifically comparing the time experienced by a traveler on a spaceship to that recorded on Earth.
  • Homework-related
  • One participant poses a question about the time recorded on a spaceship versus Earth during a round trip to Alpha Centauri at 50% of the speed of light.
  • Another participant questions whether the initial inquiry is a homework problem.
  • A participant clarifies that they are self-educating and not seeking a simple answer.
  • A suggestion is made to analyze the problem using the Earth's coordinate system to determine the time and distance for the journey, followed by applying the Lorentz transformation to convert these coordinates to the spaceship's frame.
  • Another participant proposes using the time dilation formula as a shortcut for calculating the time experienced by the traveler compared to the stationary observer on Earth.
Participants do not reach a consensus on the specific calculations or methods to be used, as the discussion includes various approaches and suggestions without definitive conclusions.
The discussion lacks specific numerical calculations and relies on general principles of special relativity, such as the Lorentz transformation and time dilation formula, without resolving the mathematical steps involved.
Individuals interested in special relativity, time dilation, and theoretical physics, particularly those seeking to understand the implications of traveling at relativistic speeds.
daenku32
Say I travel to Alpha Centauri (4.35 light-years from the Sun) AND back to Earth at 50 percent of speed of light.
How much time would the clock on my spaceship and a clock on Earth record me to have taken?
Is this a homework question?
Nope. In 28 with 3 kids. I'm just trying to self-educate myself on my spare time (the little I have).
Even if it isn't a homework problem you won't learn anything by someone simply telling you the answer, as I'm sure you know. So I'll try and give you a push in the right direction, if you have any problems with specifics just post back here and we can work them out.
Basically what you want to do is lay down what's happening in whatever coordinate system is easiest. In this case it's easiest to lay things down in the Earth's system. Say that both frames start out at the Earth at t=0, x=0. The guy in the spaceship is going to head off to the star at the given speed, so you can work out the distance and time at which this happen in Earth's frame. Likewise you can work out the time at which he returns to Earth. You can then use the Lorentz transformation to convert the coordinates of each event in the Earth's frame into the coordinates of the space ship's frame.
As a shortcut, you could also just use the time dilation formula, [tex]t \sqrt{1 - v^2/c^2}[/tex]. So, for example, if someone was moving at 0.8c for 60 minutes in my frame, then I could predict that their clock would only elapse [tex]60 \sqrt{1 - 0.8^2}[/tex] = 36 minutes in my frame.
  • · Replies 171 ·
9K
  • · Replies 21 ·
  • · Replies 29 ·
  • · Replies 34 ·
9K
  • · Replies 25 ·
