Calculating Energy Requirements for Changing Satellite Orbits
The discussion revolves around calculating the energy requirements for changing a satellite's orbit, specifically from 200 km to 3000 km above the Earth. The subject area includes concepts from orbital mechanics, gravitational potential energy, and kinetic energy.
  • Participants discuss the need to consider both kinetic and potential energy when calculating the energy required for an orbital change. Questions arise about the definition of "energy supplied" and the methods to find velocity changes and energy differences between orbits.
The discussion is ongoing, with participants exploring various interpretations of the problem. Some have offered guidance on considering total energy and delta-V, while others seek clarification on the specifics of the calculations involved.
Participants are navigating assumptions about the knowledge required for orbital mechanics and the specific calculations needed to determine energy changes during orbital transfers.
jazzchan
if i want to find the supplied energy when the satelite's orbit changed, do i need to find the its velocity or only find its K.E. ??
thanks..
Consider the total energy, PE + KE.
would u mind to tell me more ??
Why don't you explain the problem you are trying to solve? A satellite in orbit has a certain total energy, which depends on the radius of the orbit. To change the orbit, you must add or subtract energy.
my problem is one satellite is changed its orbit from 200 km to 3000 km above the Earth and from the energy was supplied.
First may i need to fidn the velocity change, then find P.E. ??
I take it that your problem is to find the additional energy that must be supplied to a satellite changing from a low orbit to a higher orbit, right?
Since I don't know what you are supposed to know about orbits, I'm not sure what to tell you yet. Tell me how you will find the speed (or KE) of the new orbit and we'll go from there.
To work this kind of problem, you'll have to know about the law of gravity and gravitational PE, and about centripetal acceleration.
sorry ! i give a mistake...
let me say again...
A satellite is uniform circular motion in an orbit 200 km above the surface of the earth. if the satellite change its orbrit to 3000 km above the Earth , how much energy must be supplied ??
I understood your problem correctly. So tell us what you've done so far.
  • · Replies 16 ·
  • · Replies 30 ·
  • · Replies 17 ·
