| Thread Closed |
Radiation reaction for a uniformly accelerated charge |
Share Thread | Thread Tools |
| Feb20-06, 06:00 AM | #1 |
Radiation reaction for a uniformly accelerated chargeRegarding my paper S. Parrott, "Radiation from a uniformly accelerated charge and the equivalence principle", Found. Phys. 32 (2002), 407-440, www.arxiv.org/gr-qc/9303025, Ted Bunn wrote: > I don't think that the author has justified his main > conclusion, which is that "purely local experiments" > can distinguish a charge in uniform acceleration > from a charge at rest in a uniform gravitational field. The paper is long, and I see now that the "justification" could have been more explicitly presented. I will try to remedy this here. First, I'd like to comment on the history of the paper, because what Bunn reasonably interprets as the "main conclusion" was not originally intended as the main conclusion. Around 1993, there was a discussion on sci.physics.research concerning whether the "fact" (or assumption) that (1) any accelerated charge in Minkowski space radiates energy (and momentum) and the "fact" (or assumption) that (2) a charge stationary relative to the Earth (say) does not radiate energy contradict the "Equivalence Principle" of general relativity. At that time, it was widely believed that this question had been definitively settled (in favor of no contradiction) by a famous paper of Boulware: D. Boulware, "Radiation from a uniformly accelerated charge", Annals of Physics 124 (1980), 169-187. For example, R. Peirels book "Surprises in Theoretical Physics" (Princeton Univ. Press, 1979) devoted a chapter to an exposition of this paper. These references were cited in the discussion as definitive evidence for the Equivalence Principle in this context. I was intrigued by the problem, and after thinking about it, came to the conclusion that Boulware's analysis did not prove what people thought. Then I wrote up my analysis in the above paper. The primary intention was to point out some questionable aspects of Boulware's widely accepted analysis, but since I had privately come to question the Equivalence Principle, I broadened the scope to include my views on this. The paper's Abstract is very short: "We argue that purely local experiments can distinguish a stationary charged particle in a static gravitational field from an accelerated particle in (gravity-free) Minkowski space. Some common arguments to the contrary are analyzed and found to rest on a misidentification of "energy". Note that it says "argue", rather than "show" or "prove". Boulware's analysis is unusually mathematically detailed, but other authors have used arguments similar to his to come to the same conclusion. A typical example is: A. Kovetz and G. Tauber, "Radiation from an accelerated charge and the principle of equivalence", Am. J. Phys. 37 (1969), 382-385. The idea of these arguments is to consider a network of observers uniformly accelerating along with the particle. Such a network may be visualized as a "uniformly accelerated" "elevator" or "rocket" containing the particle, and we'll call the observers "elevator observers". Then one can show that each elevator observer sees a vanishing Poynting vector (a vector describing the flow of electromagnetic energy radiation), which could be interpreted as seeing zero energy radiation. Thus it might seem that there is no energy radiation in the "elevator frame". But this way of speaking can be misleading because the correctness of this conclusion depends on one's definition of "energy". My paper points out that the (zero) "energy radiation" seen by the uniformly accelerated observers is *not* the same "energy radiation" which is calculated in standard electrodynamics texts. They are not merely the same quantity ("energy") calculated in different coordinate systems, but are essentially different quantities. They are mathematically different and physically different. Thus in discussions in which both "energies" appear, the use of the same term for both invites confusion. Below I will refer to the radiation "energy" given in standard texts as "Minkowski-frame energy". This "energy" is proportional to the integral of the square of the particle's proper acceleration over the accelerated portion of its worldline, and hence is always positive (or zero in case the particle is never accelerated). The other (always zero) "energy" seen by the "elevator" observers will be called the "elevator-frame energy". I can't fully explain here why they are different without writing down equations too complicated for ASCII, but the paper gives the full explanation. The idea is that the standard way of constructing a conserved "energy" in general relativity is to contract a timelike Killing vector field with an energy-momentum tensor. Usually one is lucky to find even one timelike Killing field in an arbitrary spacetime (which is why there is no law of conservation of energy in general relativity), but the so-called "Rindler wedge" in Minkowski space has the unusual property of posessing two essentially unrelated timelike Killing fields. One is time translation relative to a given Minkowski coordinatization, and the other is related to time translation as seen by "elevator" observers. The nonzero "energy" radiation calculated in electrodynamics texts comes from the former Killing field, while the (zero) "energy" radiation corresponding to the vanishing Poynting vectors seen by the "elevator" observers comes from the latter Killing field. These two "energies" are not only not numerically equal (one is zero and the other nonzero for a uniformly accelerated particle) but are conceptually and physically different quantities. Boulware calculates *both* energies (for different purposes), but does not distinguish between them. So far as I know, the mathematics leading to these conclusions has never been questioned. Any differences of opinion concern physical interpretations, not mathematics. ____________________________________________________________________ Nothing in the above questions the Equivalence Principle (EP), *per se*. It only questions Boulware's analysis leading to his conclusion that "facts" (1) and (2) above do *not* contradict the EP. My paper proper (i.e., before appendices) concludes: "Does Einstein's Equivalence Principle hold for charged particles? We cannot definitively answer this because a mathematically precise statement of the ``equivalence principle'' seems elusive --- most statements in the literature are not sufficiently definite to be susceptible of proof or disproof. However, we do conclude that most usual formulations seem not to hold in any direct and obvious way for charged particles. ..." Thus no claim is made that the paper "proves" or "shows" that the Equivalence Principle is unequivocally false. However, the paper does present a thought experiment which, if carried out physically, could in principle decide the issue. I see only one likely outcome from the experiment (the outcome which would falsify the EP), but others disagree. Bunn summarizes this experiment as follows: > The purely local experiment he has in mind is a measurement > of the force required to support the charge in its motion. > If it's at rest in a uniform gravitational field, the force > should be equal to the charge's weight. If it's accelerating > (he argues), it should be more than that, > because of the radiation reaction force. This is a good summary, assuming that "radiation reaction force" does *not* necessarily mean the Lorentz-Dirac expression for radiation reaction. It should mean the additional force (whatever it may be) necessary to "pay" for the radiated energy (as compared to an identically accelerated uncharged particle of the same mass.) It does seem to me "obvious" that if the charged particle radiates (Minkowski-frame) energy, then ordinary ideas of conservation of energy demand that an additional force must be necessary to produce that radiated energy. And, for commonsense reasons other than conservation of energy, it also seems to me "obvious" that this additional force must be active during the uniform acceleration. But since there is disagreement that the latter is "obvious", let's put this question on hold for the moment. My answer to it is given in Appendix 2 of the paper, which I will later summarize. ___________________________________________________________________ Meanwhile, let me attempt to explain why I regard it as "obvious" by rephrasing the essence of the controversy in everyday language. I often drift off to sleep while listening to a late-night radio talk show dealing with the paranormal, e.g., extrasensory perception, unidentified flying objects, and the like. It features guests ranging from obvious wackos to fringe "scientists" to reputable physicists. Sometimes it can be hard to tell the difference between them if one misses the introduction giving their credentials. One frequent guest who is a reputable physicist presents some of the wilder speculations of some string theorists (things like multiple universes) as if they were established physics. He is fond of prefacing the speculations with "we physicists believe that ...", where "..." consists of some far-out speculation which some string theorist may have published, but which is hardly a mainstream view. It is an amusing way to occupy the mind as sleep creeps in. There have been guests who claim to have worked in secret government laboratories reverse engineering flying saucers. A typical interview might go something like the following: HOST: So, Bob, you were the leader of a research group transferring flying saucer technology to automobiles? BOB: Yes, we used it to build a car that will run as long as you want without refueling. HOST (feigning unbelief): How can there be a car that will run forever? BOB: Well, it doesn't actually run forever, just as long as you want. For example, if you want it to run for one month, it will. Or it can run for a year if you want. You choose how long you want it to run, and it will run that long. We scientists say that it will run *arbitrarily long*, but that's not the same as running *forever*. HOST: Why doesn't it run out of gas? BOB: An ordinary car would, but this car can run on what we scientists call "negative gas". When the car uses "negative gas", it borrows gas from what we scientists call the "zero point quantum energy field". At the end of the trip, the user has to replace the borrowed gas. Otherwise, there would be a violation of what we scientists call the "Law of Conservation of Energy". That's why the car can run arbitrarily long, but not forever. The gas gauge in this car has not only positive numbers like 1,2,3 gallons, but also negative numbers like -1,-2,-3 gallons. If at the end of the trip the gauge reads -100 gallons, then you have to put more than 100 gallons in the tank before you can start the car. Then the gas gauge will indicate a positive number of gallons, and you can start the car. HOST: Wow, so you can drive as far as you want without stopping for gas! BOB: That's right. That's how flying saucers have been flying around the Earth for hundreds of years without refueling. When they return to their home star, they will have to put enough fuel in their tanks to cancel the negative fuel debt which they have built up. HOST: Thank you for your courage in revealing this amazing new secret technology to our audience. Nothing that Bob said directly violates any of the great physical conservation principles, but even the drowsy mind can realize that it sounds fishy. If we jazz up the story a little to "explain" how the "zero point quantum energy field" gets converted into gasoline and vice versa, it might be hard to "prove" that this car can't exist. There do exist experimentally verified quantum-mechanical effects that seem almost as strange, so one should be careful about being too dogmatic. Nevertheless, I would hope that some significant fraction of listeners would question Bob's claims. Similarly, I hope that some significant fraction of the readers of my paper will question the Equivalence Principle. Now let's get back to what we scientists call "physics". ___________________________________________________________________ Bunn considers the thought experiment in greater detail: > Start with a charge at rest in the lab, gently nudge it into > accelerated motion, let it uniformly accelerate for a while, > and then gently reduce the acceleration to zero, > leaving it in uniform motion relative to the lab. > Lorentz-Dirac theory says that there's a radiation reaction force > only during the two "nudges" at the beginning and the end -- > during the uniform acceleration, the total force > required is the same as it would be for an uncharged particle > of the same mass. And if you calculate the work done by the > external force during the whole time, it works out right: > The work equals the final energy (mc^2 + KE of the charge + > radiated energy) minus the initial energy (just mc^2). This is exactly right, as regards what the Lorentz-Dirac (LD) equation implies. And I would bet a lot of money that if the experiment could be performed, a nonzero force would have to be applied during the time *between* the nudges, i.e., during the time of uniform acceleration when the LD equation says that the radiation reaction vanishes. It's for basically the reason that I don't believe in Bob's car, but perhaps the following may be more persuasive to those who distrust argument by analogy (as do I). Suppose a small rocket ship furnishes the force to which Bunn refers. For brevity, I'll call the ship a "charged rocket". For comparison we'll also consider an "uncharged rocket" which gives the same acceleration to a particle of the same mass as the charge in the charged rocket. We'll assume that the two rockets have the same worldlines which satisfy the conditions which Bunn describes: they start unaccelerated, are gently nudged into uniform acceleration which continues for a long time, and finally are nudged back into inertial motion (i.e., constant velocity, no acceleration). For this situation, assuming Lorentz-Dirac theory, one can write down the equations of motion for the two rockets, and these equations can be solved *exactly*, with no approximations whatever. This is carried out in full detail in Appendix 2 of my paper. The result is that the uncharged rocket can accelerate *forever*, assuming that all its rest mass can be used as fuel. In contrast, if the period of uniform acceleration is long enough, the charged rocket will eventually run out of fuel (i.e., rest mass). >From that point on, its rest mass is negative (i.e., negative fuel), so its rest mass is negative at the end of the trip. It's just like Bob's car. This is not a surprising result. It could anticipated without calculation from the fact that the Lorentz-Dirac equation conserves (Minkowski-frame) energy. Since the charged rocket radiates (Minkowski-frame) electromagnetic energy, for a long enough journey, the radiated energy will exceed the initial fuel supply (i.e., rest mass). Hence the final rest mass must be negative to "pay" for the radiated energy. The detailed solution of the equations merely confirms this intuitive expectation. Thus the Equivalence Principle combined with the Lorentz-Dirac radiation reaction expression seems to demand the existence of negative mass, which has never been observed. (Of course, I can't "prove" the nonexistence of negative mass.) ___________________________________________________________________ This post is already longer than I would like, but I'd like to make one more comment before closing. Bunn writes: > Granted, Lorentz-Dirac theory is sick, but this is the sort of > situation in which it's expected to be approximately correct > (acceleration for only a finite period, > all nudges smooth and gentle). That "this is the sort of situation in which [Lorentz-Dirac theory] is expected to be approximately correct" is a common misconception. To explain why, I need first to discuss one of the lesser-known ways in which Lorentz-Dirac theory is "sick". Eliezer proved in 1943 (while a student of Dirac!) that the Lorentz-Dirac equation implies that under some physically reasonable conditions, charges of opposite sign *repel* each other instead of attracting as expected: C. J. Eliezer, "The hydrogen atom and the classical theory of radiation", Proc. Camb. Phil. Soc 39 (1943), 173 ff. This is a rigorous mathematical theorem, whose proof requires no approximations or "hand-waving". It was occasionally questioned in the literature around 1960, but it has stood the test of time and today seems universally accepted. Eliezer's original proofs were not easy to read, and subsequently several authors have published more accessible proofs, though all known to me are based on Eliezer's original ideas. Naturally, people were reluctant to believe that real particles would behave as Eliezer's theorems stated, but they were also reluctant to conclude that Lorentz-Dirac theory might be fundamentally incorrect. So, they looked for ways around Eliezer's conclusion. Eliezer's original proofs assumed point particles, which simplifies the analysis. For example, one of his theorems states that if a negatively charged particle (an electron, say) starts at rest in the Coulomb field of a stationary positively charge particle (a proton, say), then although the electron may move toward the proton for a while, it *cannot* be attracted to a collision as expected, but instead will turn around before it hits the proton and will thereafter be repelled away from the proton with ever-increasing velocity. Unfortunately, his original theorems didn't estimate how close the electron would get to the proton before turning around. So, many physicists assumed that it would have to get close enough for the proton's field to be so strong that "pair production" would occur, which would need to be described by quantum mechanics. There was no evidence for this assumption, but it was a way around the unpalatable conclusions of Eliezer's theorem. However, the *ideas* of Eliezer's proofs (as opposed to the statements of his theorems) provide ways of estimating how close the electron gets, and it can be shown that there are situations in which the electron turns around before it encounters strong fields. For example, under physically reasonable auxiliary hypotheses, one can recover Eliezer's conclusions using a Coulomb field cut off at both large and small distances from the proton, and these cutoffs can be chosen so that the field is arbitrarily weak. One can also smooth the cutoffs so that the field is infinitely differentiable. Carefully stated theorems with full proofs can be found in: S. Parrott, "Variant forms of Eliezer's theorem, www.arxiv.org/gr-qc/0505042. [I do not intend to submit this paper for publication because the ideas of the proofs are only variants of Eliezer's, and subsequent simplifiers. It was written to convince, in private correspondence, a proponent of the Lorentz-Dirac equation that it did predict unphysical effects in situations with no mathematical singularities.] The point is that Lorentz-Dirac theory is *really* "sick". If it predicts that unlike charges repel in situations in which no mathematical pathologies are evident (e.g., all fields small and infinitely smooth, etc.) then how can one confidently identify a class of situations in which it is "expected to be approximately correct"? The point of constructing physical theories is to be able to *predict* results of experiments which have not yet been performed. A physical theory which predicts effects which have never been observed and which seem in contradiction to common experience (such as unlike charges repelling each other) should be viewed with extreme suspicion. To use such a theory to draw firm conclusions about experimentally unverified situations invites error. Stephen Parrott |
| Feb22-06, 06:00 AM | #2 |
Re: Radiation reaction for a uniformly accelerated charge
Dear Mr. Parrott Re: Your original post. I follow Edward Purcell on the problem of radiation. In his book "Electricity and Magnetism", pg 8 , "The only way we have of detecting and measuring electric charges is by observing the interaction of charged bodies". That implies radiation requires an interaction of charges, since radiation reveals the presence of charge(s). In simplistic terms, that would require an electrical potential energy p= -a*b/r such as an electron with charge "a" in a relatively +Electric nuclear field with charge "b" to reduce energy by emitting a photon, with a reduction in radius "r". In an advanced treatment using Quantum Theory that observation is spectral. It appears to me an underlying civil war has been waging where the Equivalence Principle and GR is applied to Lorentz Force (LF). In AE's classical GR1916 treatment (Dover Principle of Relativity pg 155, Eqs. 65, 66), requires the LF to vanish, in the statement kappa_sigma=0. That is in accord with the GR requirement that no absolute acceleration (ergo force) is invariant, IOW's a Frame of Reference (FoR) may be found where the acceleration is zero, such as choosing the particle apparently being accelerated as the FoR. ((The context following AE's Eq.66 is somewhat ambiguous, I quote "if kappa_sigma vanishes", but then relies on that for the needed conservation of energy and momentum in GR, and then steers us back to the energy components of the g-field in Eq.(56))), That is embodied in the absolute derivative of the 4-velocity in the equation, DU^u /ds =0 and leads easily to the geodesic equation. Moving forward, Tolman in "Relativity Thermodynamics... (Eq.103.1,2 ) and Weinberg in "Grav&Cosmo" Eq.(5.1.11) set forth a variation to AE's original treatment, by setting an absolute acceleration caused by the LF "f^u" DU^u/ds = f^u / m , to produce what appears to be an absolute acceleration. So I think the question becomes, is the LF an absolute and invariant force as Tolman and Weinberg imply or does it vanish as AE implies? I think this is an important consideration to understand GR and EM relations, and QT, so what follows is my reasoning. Given the fracture of thought dividing Nobel prize winners (Einstein & Weinberg) we should be very careful. First I dismiss Tolman's and Weinberg's geodesic solutions since their mass "m" was added by hand, into the geodesic equation without regard to a 2 body solution that is rather more sophisicated than the intention of the geodesic (actually equations of motion) in AE's 1916 Eq.(45), just after stating "the equation of motion of a point". "Point" was specified. That's important because in a Lorentz force situation, we have the masses of the relating charged particles and the stored energy in the EM-field that is ultimately the source of photonic energy emissions, that's not a simple "point". As you may recall, classical EM theory allows charged particles to spiral inwards by continuously reducing the radius and continuously transmitting energy. That means a charge may move in the direction "V" in the electric field "E" to provide a continuous force "f" such as f = q*E dot V , following the LF, f_0 = q*F_0i U^i where E = F_01 and V = U^i. However, following AE, we get, f_0 =0, in accord with 0 = q*E dot V, meaning charge "q" cannot continuously vary it's energy level, and that is physically in accord with QT. ((I term that GR conjecture a "quantum geodesic")). In my personal opinion, I think Einstein was acutely aware of the application of GR to the basis of the QT, I described above in his GR1916 applied to LF and atomic orbitals. My email is dynamiXs@uniserve.com , where X=>c. Regards Ken S. Tucker |
| Feb24-06, 06:00 AM | #3 |
spardr@netscape.net (Stephen Parrott) says...
>The nonzero "energy" radiation calculated in electrodynamics texts >comes from the former Killing field, >while the (zero) "energy" radiation corresponding to >the vanishing Poynting vectors seen by the "elevator" observers >comes from the latter Killing field. > >These two "energies" are not only not numerically equal >(one is zero and the other nonzero for a uniformly accelerated particle) >but are conceptually and physically different quantities. >Boulware calculates *both* energies (for different purposes), >but does not distinguish between them. Operationally, radiation means the ability to excite atoms. So what I would intuitively think about the meaning of these two types of energy is this: 1. For a hydrogen atom, initially in its ground state, that is undergoing uniform acceleration, whether the atom becomes excited depends on the presence of "elevator" radiation. 2. For a hydrogen atom, initially in its ground state, that is travelling at constant velocity, whether the atom becomes excited depends on the presence of "electrodynamics textbook" radiation. So I wouldn't necessarily expect the two forms of energy to give the same answers to the question "is there radiation present?". It seems plausible to me that an accelerated atom might be excited by conditions that would not excite an inertial atom and vice/versa. I assume that the issues you discuss (in the section deleted by me) about the reasonableness of the coupled Dirac/Lorentz equations make it hard to know how to investigate the question (of radiation exciting atoms) in a rigorous way. -- Daryl McCullough Ithaca, NY |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Radiation reaction for a uniformly accelerated charge
| [SOLVED] Uniformly Accelerated Linear Motion | Introductory Physics Homework | 3 | ||
| Does a UNIFORMLY accelerating charge radiate? What about radiation reaction force? | General Physics | 1 | ||
| Radiation reaction for a uniformly accelerated charge | General Physics | 2 | ||
| uniformly accelerated motion | Introductory Physics Homework | 3 | ||
| uniformly accelerated motion | General Physics | 1 | ||
