Coulomb's Law and electric force
The discussion focuses on applying Coulomb's Law to calculate the electric force between two charged objects. Object B has a charge of -5 nano-coulombs, and the distance between the objects is 3.0 cm. To convert nano-coulombs to coulombs, one must multiply by 10-9. Assuming the other object has a charge of +5 nano-coulombs and both are treated as point charges, the electric force can be calculated using Coulomb's Law.
  • Coulomb's Law
  • Charge conversion (nano-coulombs to coulombs)
  • Understanding of electric force
  • Basic knowledge of point charges
  • Calculate electric force using Coulomb's Law with given charges and distance
  • Explore the concept of electric fields around point charges
  • Learn about the implications of charge polarity in electric force calculations
  • Investigate the effects of distance on electric force in electrostatics
Students studying physics, educators teaching electrostatics, and anyone interested in understanding electric forces and charge interactions.
angel_romano
I can't seem to figure out how to do this problem. I've tried the equation for coulomb's law, but I can't get the right answer. If somebody can just help me with setting the problem up.
Two objects ar rubbed against each other. Object B gains a charge of -5 nano-coulombs. What is the electric force between the two objects when the distance between them is 3.0 cm? Also, how do I convert the nano-coulombs to coulombs?
You multiply by [tex]10^{-9}[/tex], ([tex]1 nc= 10^{-9} C[/tex]).
the question si very ambiguous. *Assuming* that the two objects were initially uncharged and *assuming* that they can be treated as point charges then the answer should be given by Coulomb's law. (what did you use for the two charges? One should be +5 nc and the other -5 nc. Also, did you put the distance in meters?)
Pat
  • · Replies 22 ·
