Shifting the origine of time in isotropic oscillator
The discussion revolves around the motion of an isotropic oscillator, specifically focusing on the equations of motion and the implications of shifting the origin of time. The original poster expresses confusion regarding the appropriate choice of time shift (to) and how it affects the equations.
  • Exploratory, Assumption checking
  • The original poster attempts to manipulate the equations of motion by introducing a time shift and questions how to determine the value of to. Other participants suggest examining the implications of setting t' to zero and comparing it to the original function.
Participants are exploring different interpretations of the time shift and its effects on the equations. The original poster has indicated a breakthrough in understanding, but the details of that resolution are not shared.
The original poster mentions constraints related to the problem statement, including the requirement to convert the solution back into terms of t after finding it in terms of t'.
esradw
I am really lost here :(
The equation of motion X(t)=Ax Cos(wt-delta(x))
Y(t)=Ay Cos(wt-delta(y))
by shifting the origine of time ( t'=t+to where I need to figure out what is appropriate for time to ) and ( Delta=Delta(y)-Delta(x) )
I am suposed to find X(t)=Ax Cos(wt) and Y(t)=Ay Cos(wt-Delta)
I wish I could give some of my work but I can't even start it right now since I cannot think of the appropriate time (to) for X , I know that it can not be 0 because then I come to the same point again.
anyhelp appreciated
thanks
I think you mean for the argument of that last function you gave to be t'. What do you get when t'=0? Compare this to what you get with the original function at the same time as measured in t (ie, in terms of to).
Yes t to be t' but in the question itself says once you find the solution with t',convert it into t .
I thought I can give to= dx/w then my equation become for X=Ax Cos( wt'-(wto+Deltax)) and when I unpack it, X/Ax=Cos(wt')Cos(dx+Deltax)+Sinwt' Sin(dx+Deltax) that has to stay only X/Ax=Cos(wt') how to come to this conclution ? How to get red of Cos(dx+Deltax))+Sinwt' Sin(dx+Deltax) I don't know :((((((
any idea?
I figured it out
thanks again
