Wrong Corollary? Weierstrass M-Test & Power Series
  • Context: Graduate
  • Thread starter Thread starter quasar987
The discussion revolves around the continuity of power series within their disk of convergence, specifically examining the implications of the Weierstrass M-test and related theorems. Participants explore the conditions under which power series converge uniformly and the resulting continuity of the functions defined by these series.
  • One participant questions the corollary that states a power series is continuous on its disk of convergence, suggesting that the uniform convergence is only guaranteed on the boundary of the disk, not the entire disk itself.
  • Another participant asserts that within the disk of convergence, the series converges absolutely and uniformly, leading to the conclusion that the power series is continuous on that disk.
  • A different participant emphasizes that uniform convergence is only established on a closed disk of radius less than R, challenging the claim that it applies to the entire open disk of convergence.
  • One participant argues that for any point within the disk, there exists a smaller closed disk where uniform convergence holds, thus supporting the continuity of the power series at that point.
Participants express disagreement regarding the conditions under which the continuity of power series can be established. There are competing views on whether uniform convergence applies to the entire disk of convergence or only to a closed subset.
Some participants reference specific definitions and conditions related to uniform convergence and continuity, indicating that the discussion may hinge on these technical distinctions. The implications of the Weierstrass M-test are also a focal point, but the exact nature of its application remains debated.
quasar987
After stating the Weierstrass M-test for series of complex functions and the "[itex]f_n[/itex] continuous and uniformly convergeant to f on E ==> f continuous on E" thm, my teacher gives as a corollary that every power series [itex]\sum a_nz^n[/itex] is continuous on its disc of convergence D(0,R). And he doesn't give a proof, as if it's trivial.
But I think the corollary is wrong. Am I right in thinking so?
The convergence is absolute over all of D(0,R), but we only know for sure that the convergence is only uniform over [itex]\emptyset = \partial D(0,R) \cap U \subsetneq D(0,R)[/itex]. Hence, so is the continuity.
Corollary: A power series is continuous on its disc of convergence.
Proof: On its disk, it converges absolutely and uniformly. In particular, it converges uniformly. What does it mean for a power series to converge uniformly? It means that the sequence of partial sums, as a sequence of functions, converges uniformly to the infinite sum. Each of these partial sums is a polynomial, hence continuous. So this sequence of polynomials is continuous and converges uniformly to the infinite series on the series' disk of convergence. Hence, on that disk, the power series is continuous, by the theorem.
It seems you're getting confused about the ideas of uniform continuity of a (single) function, uniform convergence of a sequence of functions, and uniform convergence of a power series (which is a particular case of a sequence of functions being uniformly convergent).
Erm. As far as I know (i.e. according to what my book says and to what the teacher wrote on the blackboard), the convergence is only uniform on a closed disk [itex]\overline{D}(0,r)[/itex] of radius 0<r<R*. Not on the whole D(0,R). Is this not true?
*I wrote this in a very complicated manner in the original post.
Bit- given any point, p, in the disk of convergence, of radius R, there exist an r< R so that the point is inside the closed disk of radius r. Since convergence is uniform inside that closed disk, the function is continuous at p and therefore continuous on the entire (open) disk.
I see. Thanks Halls.
  • · Replies 22 ·
