Steps for Forging Bevel Gears: A Comprehensive Guide
  • Thread starter Thread starter vincentpt99
    Gear
The manufacturing of bevel gears primarily involves forging, followed by several secondary machining processes to achieve precision. While smaller gears can be produced through extrusion, larger gears necessitate forging due to their tight tolerances. Key techniques in the gear manufacturing process include hobbing, grinding, and shaping. For comprehensive information, the American Gear Manufacturing Association (AGMA) is a recommended resource.
  • Understanding of bevel gear manufacturing processes
  • Familiarity with forging techniques
  • Knowledge of hobbing and grinding methods
  • Awareness of precision machining standards
  • Research the American Gear Manufacturing Association (AGMA) resources
  • Learn about gear hobbing techniques and applications
  • Explore gear grinding methods for achieving tight tolerances
  • Investigate the shaping process in gear manufacturing
Manufacturing engineers, mechanical engineers, and anyone involved in the production and design of bevel gears will benefit from this discussion.
vincentpt99
the question given is this
" Gears can be made of forging especially bevel gears. Through literature survey describe the sequence of manufacturing steps involved in the production of gears."
what i thought is that the gear should be manufactured by extrusion, and then cut it into pieces. but the question had said that gear is manufacture by forging. after i search the internet, no website tell me how to manufacture gears.:cry:
can someone help me to solve this question, please...
There is plenty of information out there, you just have to hunt for it. Machinery's Handbook has an entire chapter on gears and splines.
Small gears can be manufactured by extrusion, but that is not the case for larger gears, especially those that require tight tolerances and high precision. A lot of gears can be made from forgings, but will have many secondary machining steps after to finish the part.
I would highly recommend that you start with the American Gearm Manufacturing Association's website (AGMA): http://www.agma.org
I would suggest looking into the following terminology:
- Hobbing
- Grinding (in regards to gear grinding)
- Shaping
I wrote this assuming that you are referring only to metallic gears, not polymer based.
  • · Replies 42 ·
  • · Replies 66 ·
  • · Replies 38 ·
