Potential difference and Kinetic energy
The discussion centers on calculating the potential difference experienced by a 4.0g object with a charge of 20µC, which accelerates to a speed of 2.0 m/s. The key formula used is the conservation of energy, specifically equating the kinetic energy gained (KE = 1/2 mv²) to the electrical potential energy (E = qV). By rearranging the equation, the potential difference (V) can be determined as V = (1/2 mv²) / q. This approach effectively demonstrates the relationship between kinetic energy and electric potential energy in the context of charged particles.
  • Understanding of kinetic energy calculations (KE = 1/2 mv²)
  • Familiarity with electric charge and potential difference concepts
  • Knowledge of conservation of energy principles
  • Basic grasp of units in physics, particularly joules and coulombs
  • Explore the relationship between electric fields and forces on charged particles
  • Learn about the work-energy theorem in the context of electric potential
  • Investigate the concept of electric potential energy in different configurations
  • Study advanced applications of kinetic energy in electric circuits and systems
Students of physics, electrical engineers, and anyone interested in the principles of energy conservation and electric forces acting on charged objects.
donjt81
A 4.0g object carries a charge of 20uC. The object is accelerated from rest through a potential difference, and afterward the ball is moving at 2.0 m/s. What is the magnitude of the potential difference?
I know i have to use the law of conservation
Potential_initial + KE_initial = Potential_final + KE final
Potential_initial + 0 = 0 + KE final
but I don't know what to do after this. can some one give me any pointers?
The object gained some amount of kinetic energy, which can found with
[itex] KE = \frac{1}<br /> {2}mv^2 [/itex]
This energy had to come from somewhere; in this case, it came from an electric field.
The amount of energy gained by an object of charge q, moving through a potential difference of V volts is:
[itex] E = qV[/itex]
The easiest way to realize this is simply to look at the units. The "volt" is exactly equal to one joule per coulomb. Look at how the factors cancel if you use this definition of the volt:
[itex] {\text{20}}\,\mu {\text{C}} \cdot V\frac{{{\text{joules}}}}<br /> {{{\text{coulomb}}}}[/itex]
The coulombs cancel, leaving you with just joules.
All you need do is to solve for V, such that the gain in kinetic energy is equal to the loss of electrical potentail energy:
[itex] \frac{1}<br /> {2}mv^2 = qV[/itex]
- Warren
  • · Replies 21 ·
