K in Hookes Law vs. Spring Potential Energy
The discussion centers on the discrepancy between the spring constant (K) calculated using Hooke's Law and the value derived from potential energy equations in a spring-ball system. The instructor and students identified that K can differ by a factor of 2 depending on the context of the problem, particularly when considering the positions of the ball at the top and bottom of its bounce. The key equations presented include the potential energy equations and the force equations, highlighting that K is influenced by the spring's stretch and the gravitational potential energy at different heights.
  • Understanding of Hooke's Law and its equations: F = kx and T = (kx)/L
  • Knowledge of gravitational potential energy: mgh
  • Familiarity with concepts of kinetic energy and conservation of energy
  • Basic understanding of spring mechanics and oscillatory motion
  • Study the derivation of potential energy in spring systems using conservation of energy principles
  • Explore the implications of different spring constants in various physical scenarios
  • Learn about the relationship between spring force and displacement in oscillatory motion
  • Investigate the effects of mass and height on spring potential energy calculations
Students of physics, educators teaching mechanics, and anyone interested in understanding the nuances of spring dynamics and energy conservation principles.
jeffholmes1
Today in physics class we were discussing the conservation of energy using a ball on a spring as the example. When the instructor completed the problem one of the students stated that the value of K (spring constant) that we found was different (by a factor of 2) than the value of K calculated using Hooke's Law. The instructor could not figure out why the values of K were not the same. Why are they different?
Potential Energy(before)=Potential Energy (after)
(1/2)kx^2+mgh = (1/2)kx^2+mgh
ball on spring at rest = ball on spring extended
2mgh
---------- = k is not equal to k= F/delta h
X^2
You can equate the sum of these Potential Energies only if KE = 0.
This will occur at the bottom of the bounce and at the top of the bounce.
[tex]\frac{1}{2} k x_{bottom}^2 + m g h_{bottom} = \frac{1}{2} k x_{top}^2 + m g h_{top}[/tex]
suppose the spring was unstretched at the top, so x_top = 0 ;
suppose we measure height from the bottom , so h_bottom = 0 .
Then : (1/2) k (x_bottom)^2 = m g h_top
=> k = 2 m g h_top / (x_bottom)^2 = 2 m g / x_bottom .
The adjectives "top" and "bottom" are important here. The ball was moving
- in particular, the acceleration was NOT = 0 in either location.
The Force by the spring when the ball was at the bottom was
F = - k s = - [2 m g / x_bottom] x_bottom = - 2 m g (upward).
The Force by the spring when the ball was at the top was zero.
The average Force by spring during this motion was F_average = - m g .
The form to remember is F = - k s , which will remind you that
s is the stetch of the spring from its "relaxed" length.
(not to be confused with horizontal coordinate "x" , nor with height)
There are two versions of Hooke's law:
[tex]T = \frac{kx}{L}[/tex]
[tex]F = kx[/tex]
Each equation will yield a different value of k for a given tension or (after integration) potential energy.
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 58 ·
