A problem like Fermat's Last Theorem
  • Context: Graduate
  • Thread starter Thread starter kmarinas86
    Theorem
The discussion revolves around the equation a^n + b^n = c^n, where a, b, and c are non-zero integers and n is a real number greater than 2. Participants explore whether solutions exist for this equation, drawing parallels to Fermat's Last Theorem.
  • Some participants suggest starting by choosing specific values for a, b, and c before focusing on n.
  • One participant emphasizes that the equation should be analyzed with non-zero integers for a, b, and c, similar to Fermat's Last Theorem.
  • Another participant argues that the established proof for integer n does not necessarily apply to the case where n is a real number.
  • Some participants propose using the intermediate value theorem to find conditions under which solutions exist.
  • A participant presents a specific case (3^x + 3^x = 4^x) and derives a solution for x, claiming it demonstrates the existence of solutions.
  • There are assertions that infinitely many solutions can be found using basic mathematical principles, including the intermediate value theorem.
  • Some participants express frustration over perceived lack of direct answers to the original question.
Participants do not reach a consensus on whether solutions exist for the equation under the specified conditions. Multiple competing views remain, with some arguing for the existence of solutions and others questioning the validity of those claims.
Participants reference the historical context of Fermat's Last Theorem and its implications for the current discussion, but the applicability of the theorem's proof to the case of real n remains unresolved.
kmarinas86
A "problem" like Fermat's Last "Theorem"
Given the equation:
[itex]a^n+b^n=c^n[/itex]
Where:
a, b, and c are integers.
And n is real number greater than 2.
Is there a solution?
edit: a, b, and c are supposed to be non-zero like in Fermat's Last Theorem
Yes. Try picking a, b, and c before you worry about n.
But a, b, and c are supposed to be non-zero integers. That's what Fermat's Last Theorem is about.
Okay, pick them to be nonzero integers. Then worry about n.
You asked whether there were any positive integers a, b, c, such that, for some n, an+ bjn= cn. Hurkyl's suggestion was that you choose suitable a, b, c, then look for a value of n.
That doesn't answer my question though.
As your first task, let a and b be the same integer.
Woe is you. These people sure are mean when they don't tell you the solution straight away.
Fermat's Last Theorem goes like this:
Where a, b, c, and n are all integers:
And where n is an integer greater than 2,
There can be no a, b, c, n, where:
http://www.google.com/search?q=fermat's+last+theorem
What non integer n should I use then? There are literally an infinite amount. I would choose n first because it was already proven that the formula does not work where n is an integer.
Do you understand that it took hundreds of years to prove Fermat's Last Theorem? It looks so simple, but it's not. By experience it is known by mathematicians that there is no such thing as a simple proof "thus far" of Fermat's Last Theorem. Therefore, the answers I have gotten so far have been inadequate.
I haven't found any substantation whatsoever whether or not the no solution answer (which was proven for the n=integer case) applies for the n=real number case.
Of course it doesn't apply. And I think those people who posted here to help you are more than familiar with the history of FLT, and quite a few might even know about Wiles's proof.
Fix a<b<c and you're asking if a^n+b^n-c^n= 0. Try and find some simple conditions to ensure that there is some n where this happens. Hint: intermediate value theorem, and try to be polite to other people who are trying to help you to help yourself, it really is quite straight forward to find infinitely many a,b,c and n real and greater than 2, as a really big hint try a=b=1 and *any* c larger than 2 for an idea (if you want n>2 then try a little harder, though why n=1.5 won't do I'mi not sure).
NB fixing n can't help you at all, and you are after all trying to show that there is some n for which there are integer solutions, and as you observe there are infinitely many to choose from, so don't choose it first.
1^2.5 < 1^2.5+1^2.5 < 2^2.5
1^3.5 < 1^3.5+1^3.5 < 2^3.5
In general
1^x < 1^x+1^x < 2^x
for any x greater than 1
where
1 < 2 < 2^x
There is no integer between 1 and 2.
Where x>2:
1^x+1^x < 2^x
1^x+1^x > 1^x
For any:
a^n+b^n=c^n
Where a, b, and c are integers, and n is a real number.
the nth root of (a^n+b^n) must equal an integer.
Sorry, what does that show?
It is easy to find infinitely many (strictly positive) integer a,b,c and real n>2 with a^n+b^n=c^n using the intermediate value theorem with, so try doing it
It means:
In general
1^x < 1^x+1^x < 2^x
where
1 < 2 < 2^x
Where x>2:
1^x+1^x < 2^x
1^x+1^x > 1^x
This proves that for the equation:
1^x+1^x = c^x, where x>1
c cannot be an integer. It must be a number between 1 and 2. Of course, this is not a formal proof, but a formal proof can be derived from this. In fact, c must be the xth root of 2.
because
1^x+1^x = 2
Also
Any root of 2 cannot ever be less than 1.
And 1^x = 1.
And 2 to any xth root cannot ever be an integer. (for any x > 1)
You're right:
If you look at the graph below, you'll see that for x>2 as x approaches infinity, the graph line becomes asymptotic. Soon I will post a graph that has a bunch of lines, maybe dozens, that will probably show the same thing. But I have found, that indeed, there are solutions.
It is very easy to do (to find infinitely many a,b,c integers and n a real larger than 2). We are not lying to you, nor are we pretending not to know the answer when we don't. Do you know what the intermediate value theorem states? That is all that is required, and a little thought (the case a=b=1 surely tells you something, how about making a=b=4?), and infinitely many solutions can be shown to exist by anyone who's done a first course in analysis.Instead of assuming that we're all wrong, why don't you possibly consider that we might be right and try following the hints you've been given? You'll learn more by doing so. As I say, infinitely many examples can be shown to exist by anyone with a first course in analysis behind them.
Let me help even more by pointing out that n=log(1/2)/log(4/5) which is greater than two will have integer solutions to a^n+b^n=c^n.
Indeed, now I come to think of it anyone with high school maths can create arbitrarily many examples. A first course in analysis will explain 'why' this is possible. As I say, it is merely the intermediate value theorem.
Solution for 3^x+3^x=4^x:
ln(2)/ln(4/3)=x
How to get it:
3^x+3^x=4^x
2*3^x=4^x
2=(4/3)^x
ln(2)=ln(4/3)*x
ln(2)/ln(4/3)=x
a, b, c are all integers, and x is a real number.
Mystery solved :smile:
It's ok, I figured out on my own before I saw this post :smile:
  • · Replies 105 ·
12K
