How Do I Calculate Reactions for a Fixed Cantilever with Uneven Loads?
  • Thread starter EQ
  • Tags
    Reactions
In summary, the conversation is about finding reactions for a fixed cantilever with a total length of 16ft and loads of 2000 lbs and 1000 lbs placed at different points. The support for the cantilever is located at point A, 6ft from the left, and the dimension for the 1000 lb load is 6ft from the fixed point of the cantilever, point B. The individual has been summing the moments at A and B and found numbers that may not be accurate. They are looking for help in solving this hyperstatic system using differential equations to express reactionary moment and force in terms of the reaction at support A.
EQ
I need help finding reactions for a fixed cantilever. total length is 16ft and its fixed on the right side. The loads on it going from left to right. 2000 lbs at the end of the left. 1000 lbs 10ft from left. There is one support for the cantilever and its where A is at which is 6 ft from left. The dimension for the 1000 lb load is 6ft from B which is the fixed point of the cantilever.
I've been summing the moments at A and B and my numbers are 3800 at A and 800 at B with a zero torque moment at B which is not right, it has to have a torque moment doesn't it?
Please help if you can.
2000...10ft...1000...6ft...
|_______________|_________ B Fixed End
...6ft... A .....10ft...
Thanks
This is a hyperstatic system solved by differential equation of the deflexion curve. So what you should do is express reactionary moment in terms of the reaction at support A, and the reactionary force in B in terms of the reaction at support A, then start making your sections (bending moment equations).
for reaching out for help with your cantilever problem. I am happy to assist you in finding the reactions for your fixed cantilever.
First, let's review the concept of moments and torque. Moments are the product of a force and its distance from a reference point. In this case, we are summing the moments at points A and B to find the reactions. Torque, on the other hand, is the measure of a force's ability to cause rotational motion around an axis. It is calculated by multiplying the force by the distance from the axis of rotation.
Based on the information provided, it appears that you have correctly summed the moments at point A to be 3800 lbs. However, the moment at point B is not correct. Since point B is the fixed end of the cantilever, it cannot rotate and therefore has no torque moment. The moment at point B should be zero, as you have correctly noted.
To find the reaction at point A, we can use the equation: ΣM=0, where ΣM is the sum of the moments and must equal zero for a static equilibrium. Plugging in our known values, we can solve for the reaction at point A:
(2000 lbs)(10 ft) + (1000 lbs)(6 ft) - RA(6 ft) = 0
20000 ft-lbs + 6000 ft-lbs - 6 ft x RA = 0
26000 ft-lbs = 6 ft x RA
RA = 26000 ft-lbs / 6 ft
RA = 4333.33 lbs
The reaction at point A is therefore 4333.33 lbs, which is the upward force needed to balance the downward forces of the loads on the cantilever.
I hope this helps you find the correct reactions for your fixed cantilever. Remember to always carefully consider the concepts of moments and torque when analyzing a structure. If you continue to have trouble, it may be helpful to consult a structural engineer or seek additional resources for support. Good luck!
1. What is the purpose of strengths finding reactions?
The purpose of strengths finding reactions is to identify an individual's unique strengths and talents in order to maximize their potential and achieve personal and professional success.
2. How are strengths finding reactions different from traditional performance evaluations?
Unlike traditional performance evaluations, strengths finding reactions focus on identifying and developing an individual's strengths rather than pointing out weaknesses and areas for improvement. This approach is more empowering and can lead to greater motivation and productivity.
3. How can strengths finding reactions benefit an organization?
By identifying and utilizing the strengths of each individual, strengths finding reactions can create a more diverse and dynamic team, increase employee engagement and satisfaction, and improve overall performance and productivity of the organization.
4. What are some common methods used for conducting strengths finding reactions?
There are various methods for conducting strengths finding reactions, including self-assessment tools, peer feedback, and one-on-one coaching sessions. These methods may also be combined to provide a more comprehensive understanding of an individual's strengths.
5. Can strengths finding reactions be used for personal growth and development?
Yes, strengths finding reactions can also be used for personal growth and development. By identifying and developing one's own strengths, individuals can gain a better understanding of themselves, improve their self-confidence, and achieve their personal goals.
  • Mechanical Engineering
12K
