Create an Eye-Catching Embedded Text Effect with Depth and Dimension
  • Thread starter Thread starter sid_galt
    Text
The discussion centers around creating a text effect that gives the impression of depth and dimension, making the text appear as if it is embedded in the background while also protruding outward. The context is primarily focused on web design and graphic effects.
  • One participant describes a desire for text that appears to come out of the background, seeking methods to achieve this effect.
  • Another participant humorously questions the context of where the text will be used, suggesting unconventional placements.
  • A participant clarifies that the text effect is intended for a web page.
  • One suggestion involves using Photoshop to create a gradient effect, along with mentioning a free online tool called FlamingText for generating similar effects.
  • Another participant proposes that the desired effect may be a bevel effect and mentions using Fireworks with a specific plugin for achieving such effects, although they note they haven't applied it to text.
Participants have not reached a consensus on the best method to achieve the desired text effect, with multiple suggestions and interpretations of the effect being discussed.
Some suggestions depend on specific software tools, and there may be assumptions about the participant's familiarity with graphic design programs and techniques.
sid_galt
I want a type of effect in my text so that the text seems to be coming out of the background. So that the text seems embedded into the background but still having depth and protruding out? Unfortunately I don't have an image to show, I have only seen it a few times. I hope you understand what I mean.
Is there any way to create such an effect?
Computer science news on Phys.org
Where would you like this text to be? On your dog's water bowl? Tattooed on your chest?
I want this text to be on my web page ofcourse
If you only wanted small amounts i suggest using a program such as photoshop and adding a gradient or something simillar... i believe there is a free online gif generator called flammingtext or something if you search for it, I'm sure you will find it.
Isn't that a bevel effect you want then? I usualy use Fireworks, with Eye Candy's "Bevel Boss" effect to do stuff like you mentioned, though i never did it with text.
  • · Replies 36 ·
  • · Replies 527 ·
46K
