| Thread Closed |
Is special relativity consistent with thermodynamics? |
Share Thread |
| Jan14-04, 05:33 PM | #35 |
Is special relativity consistent with thermodynamics?Things that are far apart and relatively moving don’t even know the other things are moving “relative” to them. This is just a big urban legend and a form of “magic” in science, due to a mistake Einstein made in his 1905 SR paper. Einstein corrected his big 1905 error in a paper he wrote in 1918. In 1918 he found he needed to add a gravitational field to the 1905 theory and the 1905 clock had to be turned into an atomic clock, since the same effect won't work on a mechanical clock. You can find his 1918 paper in this modern book at any big university library: "Dialogue about Objections to the Theory of Relativity" "Dialog über Einwände gegen die Relativitätstheorie" Die Naturwissenschaften 6 (1918) Published now in the new book: "The Collected Papers of Albert Einstein, Volume 7: The Berlin Years: Writings, 1918-1921." |
| Jan14-04, 05:53 PM | #36 |
The 1905 Einstein “constant” speed of light theory said this: “light is always propagated in empty space with a definite velocity c” But this turned out to be wrong. He learned in 1911 that light speed can change at different places in space. He also said so in his 1916 book. See page 76 of the Crown press version of “Relativity: The Special and General Theory”. In 1911 he learned that light speed can change due to light passing through a strong gravitational field. Also, an atomic clock can change rates and slow down in a strong gravitational field. So, if you measure the local speed of light inside a gravitational field with an atomic clock resting in that same field, you will measure “c” for the local speed of light. That is becaue in a gravitational field, the light slows down as the rate of the clock slows down, and the light speeds up as the rate of the clock speeds up. So an atomic clock (but not any other kind) will always measure “c” for the “local” speed of light, at the clock. But if that same clock measures the speed of light moving someplace else, away from that local gravitational field, then that clock will measure other rates other than “c”, either slightly faster or slightly slower. So, all the speculating about what happens to clocks in SR theory is wrong, and it has been wrong for 98 years. Read that 1918 paper and you’ll see what I’m talking about. Also, read his 1911 gravitational redshift paper, which is GR theory and it is ok. Gravity does not slow down “time”, it slows down atomic clocks. It speeds up pendulum clocks. It affects different kinds of clocks in different ways. Relative motion doesn’t slow down any clocks. (1905 SR theory is wrong) Acceleration does slow down atomic clocks. (1911 GR theory is correct) Acceleration might or might not slow down other kinds of clocks, depending on what kind of clock it is. (Classical clock experiments and observation, see “Harrison’s chronometer”.) Human time is “thermodynamic time”. (IE heat energy time, not atomic energy time. See any biology thermodynamic time website.) |
| Jan14-04, 07:30 PM | #37 |
Daid, Please tell me why scientist believe light speed would not change relative to the observer's speed. Any experiment and its detail.
| Jan14-04, 08:53 PM | #38 |
Einstein’s original 1905 light speed postulate is wrong: “light is always propagated in empty space with a definite velocity c”. That is wrong and he changed his postulate in 1911. It is wrong because in 1905 he thought of space as being "empty", and he did not consider the effect a gravity field has on the speed of light. His improved 1911 Law of light speed is right, as far as I can tell, but he never phrased it in a single sentence, and it is a little difficult to understand. I will try to state it here, in two sentences: 1: Light speed measured by an atomic clock will be measured at “c” at the clock, where ever the clock is located, even in a strong gravitational field, because when light speed slows down in a gravity field, so does an atomic clock, so an atomic clock is incapable of measuring a local change in the speed of light, at the place where the clock is located. 2: But, an atomic clock can measure light speed changes in different parts of space, if the light waves/photons are somewhere else, somewhere other than where the clock that measures their speed is located. This means that if we put an atomic clock at the surface of the earth, it will measure “c” for the light waves/photons that hit or pass right by that clock. And if we think of an atomic clock at the surface of the sun, that atomic clock will measure “c” for the light that hits or passes right by that clock. But if we put an atomic clock on the moon, and if we could use that clock on the moon to measure the speed of light: 1) traveling in space between the earth and the sun, 2) at the surface of the earth, 3) at the surface of the sun, and 4) at the surface of the moon, because of the gravitational field at the moon, and the atomic clock located at the moon’s surface, here is how the moon clock will measure those different speeds of light: Atomic clock resting on surface of moon measures: 1) light speed in space, the fastest local-area speed for light 2) light speed at the earth, a slower speed for light 3) light speed at the sun, an even a slower speed for light 4) light speed at the moon and at the clock, a faster speed than at the earth and sun, but not as fast as light in local deep space Here is a website where a young physics student tries to explain this. The student’s drawing is just about the same as Einstein’s 1911 drawing. Notice the two different speeds for different points along a wavefront of a light beam passing near the sun, c’dt and cdt. The “distant time” means the atomic clock that measures this speed must be well away from the gravitational field of the sun, or the clock will slow down at the same rate the light speeds slow down: EINSTEIN 1911 THEORY As Einstein brilliantly deduced in the 1911 paper, this clock/light slowdown phenomenon is caused by the strange effect of an atomic clock slowing down in places (in gravitational fields) where the local speed of light slows down. So, if the local atomic clock slows down in a strong gravitational field, and the local speed of light slows down in the same strong gravitational field, then that clock won’t notice the light speed slow-down, because the clock has slowed down too. But if that clock can be used to measure the speed of light somewhere else, such as moving between two points in space, well outside of that local gravitational field, then that clock inside the field will measure a faster speed of the light between the two points, as long as those points are far away from any strong gravitational field. So, the first 1905 postulate is not correct, because light does change speed as it moves from place to place. It travels the fastest when the waves/photons are a long way from a strong gravitational field, and it travels slowest when it passes through a strong gravitational field. But this phenomenon is often misunderstood, since atomic clocks are used to measure the exact speed of light, because atomic clocks are the most accurate. Atoms, which emit the light in the first place, slow down their internal harmonic oscillation rates when they are subjected to strong gravity, and that is why an atomic clock will measure “c” as the “local” speed of light at the clock that measures the local speed. This is very confusing, since his 1911 paper is not very clear and is also confusing, and people get the original 1905 postulate mixed up with his 1911 Law. Even many physics professors seem to think the 1905 “postulate” is correct, but it isn’t. His 1911 “Law” is correct. Some people get mad at me when I say, “Einstein made a mistake in 1905”, but he corrected his own mistake in the 1911 paper and in his 1918 paper. I guess he got tired of trying to explain the difference between the 1905 postulate and the 1911 Law, so he never wrote very much about the difference after 1918. I just discovered this recently. There is a new paper about it, published in the European Journal of Physics, titled “Einstein and the Twin Paradox”. That tells about his 1918 correction. Also, Wolfgang Pauli wrote a relativity book in 1921, and he tells about the change and the 1918 Einstein correction to the 1905 theory. These are the only two places I’ve ever seen mention of Einstein’s 1918 correction. I’ve ordered a copy of his 1918 paper, but it hasn’t arrived yet. What I’m telling you now was known among many physicists and professors in the 1920s, but the information seems to have been lost or forgotten or neglected over the years. Now, everybody who reads his 1905 paper thinks the 1905 postulate is correct, but it’s not. The 1911 Law is correct, but that paper is much more complicated, so not many people understand it. I had to study that 1911 paper, and compare it with the 1905 paper, for more than 10 years before I began to understand the subtle differences in what he was saying in the two papers. But if you ask some professors or some physicists, they will say I am wrong. That’s because they are not aware of his 1918 correction to the 1905 theory. But if you read that young student’s website, you will see that he explains the slowdown of light near the sun, in terms of a “distant clock”. Unfortunately, he doesn’t explain why a distant clock needs to be used. |
| Jan14-04, 09:07 PM | #39 |
David, This is my part of calculation.
Assume v=c*sinA. T=T'*(1/sqrt(1-v^2/c^2))=T'*(1/cosA), X/T=v. X=280 light years, T is the static observer's time, T' is the mover's time. T'=30 years. so 280c/(30/cosA)=c*sinA. 280/30*cosA=sinA. tanA=sinA/cosA=280/30. sinA=280/sqrt(280^2+30^2)=0.9943. So if the mover's speed is 0.9943c relative to the static observer, the mover will arrive at a star 280 years far away in 30 years in the mover's time. cosA=30/sqrt(280^2+30^2)=0.1065. T=30/0.1065=281.6901. To the static observer, the mover will arrive at the star after 281.6901 years. It's not 300 years in my question. Sorry. I threw out some figures just want to show the mover's time is actually less than 280 years. So, the static observer will believe the mover moving in a speed less than c. To the mover, it did not move but the start moved to him, the distance is 280*0.1065=29.82 light years. So, the star is moving toward him in the speed of 29.82c/30=0.9943c. None of each sides violate the maximum light speed and they are exactly the same magnitude but different direction. Hope I did not messup the calculation. It's my understanding of SR. Maybe I am wrong. The mass is now m0/0.1065=9.3897m0. The mass was increased mare than 8 times of rest mass. E=mc^2=9.3897m0*c^2. The Energy required to push a rest spaceship to such speed will be at least 8.389m0*c^2. I did my part of math. As I have stated, maybe you are right. From your model, how will it look like? Can you answer my last question also. |
| Jan14-04, 09:09 PM | #40 |
Daid, Do not forget about muon phenomenon and Theo... experiment.
| Jan14-04, 09:17 PM | #41 |
Lorentz predicted similar phenomena due to motion of atoms and particles through fields as early as 1895. He even predicted mass increase due to “acceleration” in 1904. The Muon phenomenon is NOT due only to “relative motion”. Same with the Ives-Stilwell experiment of 1938. Their electrons were accelerating AND moving through the earth’s gravitational field. Hafele-Keating experiment. The clocks were MOVING THROUGH the earth’s gravitational field. That’s why Westbound clock speeded up and Eastbound clock slowed down. Einstein in 1905 prediced ONLY SLOWDOWN in both directions of motion. That was wrong. |
| Jan15-04, 08:08 AM | #42 |
David, My final say about this.
My calculation in last reply violated principle of relative motion. If 280 years of static observers is 30 years of mover, then 30 years of movers shall be 280 years of the static observer. Agreed. Check the other experiment, the 3-light-second-long rocket and the 5-light-second-long tunnel ( I changed it now from 4 second to 5 second, easier to calculate. I hat calculation ). First event A, the front of the rocket reaches the open end of the tunnel. Second event B, the rear of the rocket reaches the open end of the tunnel. The light beam was sent at the point from the rear of the rocket or/and the open end of the tunnel. Third event C, The front of the rocket reaches the other end of the tunnel. At the same time, the light beam reaches the fron ot the rocket and this end of the tunnel. So what we can be ceratin is the light shall have travelled three seconds for the rocket, because if you are in the rocket, you see the light travel from the rear to the end for 3 light seconds. No ambiguity here. You are a static observer and you knoe it's built with 3 light years long. Now, if you sit at the close end of tunnel, you know the light travelled for 5 seconds. No ambiguity here, either. That means T'=TcosA. 5=3cosA. cosA=3/5. sinA=4/5. T' is the rocket's time, and T is the tunnel's time. v=c*sinA. The required rocket's speed is 4/5c relative to the tunnel. Now, let's discuss the interval between event A and event B. This interval represent the time for the rocket passing through the open end of the tunnel. If you, working for the tunnel, installed a gate here, you open the gate when the front of the rocket arrived and shut the gate to cut the rocket at the last moment. Since the speed is 4/5c to you and the rocket is 3 light-second long as you already know as part of the experiment's participant. 3c/(4/5c)=15/4=3.75. The rocket will need 3.75 seconds to go through the gate. All you need to do is close the gate after 3 seonds to cut the rocket into two pieces. No. the rocket has shrunk to you also. The 3 light-second rocket will appeared to you only 3c*(3/5)=9/5*c=1.8c. It will pass the gate in 1.8c/(4/5c)=9/4=2.25 seconds. I hope I did not do this wrong. It usually took me a month to check through the thought of this experiment. You have to draw an event shadow in the Minkowski diagram to visualize how this works. This is the best I can do in writing without Minkowski diagram. If you are not interested in what I say here. I guess our paths just do not cross. Thanks for your lesson, any way. |
| Jan15-04, 03:56 PM | #43 |
| Mar24-05, 08:25 PM | #44 |
After I read all of this discussion, I recall a question I posted several months ago, about the connections between the thermodynamic internal energy and the relativistic rest energy. Specifically, it is the thermodynamic internal energy U equal to the rest Einstein´s energy at rest ( E= m c2)?. Is E= U?.
| Mar25-05, 02:16 AM | #45 |
If you walk behind hoofprints, what do you expect to find? Advice: don't kick the fresh ones. If you wish to 'correct' the Einstein equations, at least use the ones near and dear to our hearts... i.e., the ones that actually apply. That said, I do appreciate the insights on particle physics. Pottery magicians, go figure.
| Mar25-05, 07:46 PM | #46 |
Recognitions:
http://lanl.arxiv.org/abs/gr-qc/9803007 which looks like it addresses the topic in some detail. I haven't really studied the whole paper very closely, but I think it might be of interest to you. There are a few things the author of the above says that still puzzle me a bit - for instance, I'm not quite sure how entropy gets turned into a current, since it isn't conserved. But it seems reasonably straightforwards to me that thermal energy should be treated like any other form of enregy, with a stress-energy tensor, as the author suggests. Personally, though, I find it just as easy to use the old-fashioned non-Lorentz-invariant defintion of temperature, with the appropriate restriction of using the concept only n the frame where it applies. (This wouuld be the frame that's comoving with the fluid element.) That's the approach that MTW uses, for instance, in their discussion of thermodynamics in stellar interiors, which I've already mentioned. |
| May5-11, 07:49 PM | #47 |
David, you are wrong about your claims about SR. First, you are claiming that one of the most experimentally accurate theories in modern science is "wrong." You are claiming that SR is wrong and GR is right. They are both right, SR is ONLY to be used in an inertial referenece frame, i.e. one without any acceleration, gravitation, or rotation (or one where there are no fictitous forces such as centrifugal). GR is more general (hence the general relativity), and applies anywhere. When there is free space (devoid of any mass-energy) light DOES propogate at c. You seem to be under the impression that SR is corrected by GR, but is actually generalized. You cannot employ GR, without accepting the postulates and theory of SR>
| May5-11, 07:59 PM | #48 |
Also, you seem to think that time dilation is a result of a "force." This is not true in either SR or GR. Time dilation is a result of the warping of 4-D space in order to account for its true, world line. In SR, this simply means that, heuristically, "time must slow down so that the speed of light can be invariant." In GR this effect is further augmented by a massive objects warping of space through the EFE's. There is no "force" acting on an object to dilate it's relative time." You often quote physicists, yet you do not understand their work. You simply reject their tried-and-true formulas and equations and substitute poorly formulated replacements.
| May5-11, 08:51 PM | #49 |
David said "So an atomic clock (but not any other kind) will always measure “c” for the “local” speed of light, at the clock."
This is wrong. Your wristwatch would measure c just like the atomic clock. All clocks are equivalent in SR and GR. Your growing beard is a clock no different than an atomic clock to SR. |
| May5-11, 09:19 PM | #50 |
Mentor
Most of this thread is 7 years old.
| Thread Closed |
Similar discussions for: Is special relativity consistent with thermodynamics?
| How much is Special Relativity a needed foundation of General Relativity | Special & General Relativity | 97 | ||
| Consistent with special relativity? | Special & General Relativity | 10 | ||
| question concerning thermodynamics and special relativity | Special & General Relativity | 0 | ||
