Bicycle Tire Question: Why Does Air Loss Affect Cycling Difficulty?
  • Context: Undergrad
  • Thread starter Thread starter fotonios
    Bicycle Tires
The discussion revolves around the effects of air loss in bicycle tires on cycling difficulty, exploring the underlying physics of rolling resistance and tire deformation. Participants examine various factors contributing to the increased effort required to cycle with low-pressure tires, including energy loss and torque generation.
  • Some participants suggest that energy is lost in deforming the rubber of the tires and shifting air when the tires are under-inflated.
  • Others argue that the increased area of contact between the tire and the road leads to greater rolling resistance, making low-pressure tires harder to push.
  • One participant challenges the relevance of contact area by stating that the contact point does not move with respect to the road, questioning the frictional resistance argument.
  • Another viewpoint emphasizes that soft tires create a torque on the wheel due to the redistribution of the normal force, which must be overcome to maintain motion.
  • A participant expresses appreciation for the explanation regarding the torque and normal force distribution, indicating it clarifies their understanding.
  • However, another participant raises a question about the symmetry of the normal force acting on both sides of the axis of rotation, suggesting a potential oversight in the previous explanations.
  • A response counters this by stating that the footprint of the tire is distorted towards the front, implying asymmetry in the forces at play.
Participants express differing views on the primary reasons for increased cycling difficulty with low-pressure tires, with no consensus reached on the most significant factors involved.
Some claims rely on assumptions about tire behavior and forces that may not be universally accepted or fully explored, leaving room for further investigation into the mechanics of tire deformation and rolling resistance.
fotonios
bicycle tires question...
ok...heres a question that was given in the interview to a student who wanted to study physics at cabridge university.
why when there is air loss in the tires of a bicycle(pressure decrease)...the bicycle becomes(heavier)?,meaning...harder to cycle.
There is a bunch of energy that goes into deforming the rubber of the tires and shifting the air around that doesn't get used if the tires are filled.
thats true...but its not by far the main reason of the huge difference in the effort u have to put into continue cycling.
pls try again!
I have always assumed that it was the greater area of contact between the the tire and the road which caused greater rolling resistance thus low pressure tires are MUCH harder to push down the road.
Is there more?
Is there more?
the (point),(area...) of contact of the tire with the road is stationary...the tyre at that point does't move with respect to the road...so there is no point of discusing resistance due to friction.(so the greater area of contact is irrelevant in that respect).
TRUE there is greater resistance in the rolling of the (wheel) tire...but what causes it?
i have given u a strong hint now.
I would expect that the major effect of soft tires is this: the tire is squashed forward and bunched up---essentially pulled away from the rim. In turn, the rubber pulls against the rim, creating a torque on the wheel that must be overcome to keep riding.
Looked at in terms of external forces, the normal force (the ground pushing the tires up) has been redistributed. In a firm tire, the normal force is directly underneath the center of the wheel. In the soft tire case, the normal force is now squashing the rubber in front of center. Thus the normal force now exerts a torque on the wheel.
you got it!
good thinking!
and good and complete explanation...not just a dry answer.
you should apply for cabridge...:)
Ahhh! Beautiful! It makes very good sense now.
Thanks for completing a picture for me.
I am not fully convinced. Wouldn't the normal force also act (equally) on the other side of the axis of rotation, that is, at the back end of the footprint?
No, since the "footprint" is not symmetric. The footprint is distorted towards the front.
  • · Replies 16 ·
20K
  • · Replies 16 ·
19K
