| Thread Closed |
Initial Value Problem (with y(0) ?!) |
Share Thread |
| Mar25-06, 06:12 AM | #1 |
I (kind of) understand how to do initial value problems. I know that if the problem is [tex] y' = x, y(4) = 3[/tex] then you just differentiate it, solve for y(4) and then replace the constant C (in the equation I differentiated) with this answer.
But what if the initial value is y(0) = 6?? The problem I am trying to do is: [tex] y' = 36 + y^2 [/tex] [tex]y(0) = 6 [/tex] [tex] 0 < c < \frac{\pi}{2} [/tex] Differentiating, I get [tex] y = 36y + \frac{1}{3}y^3 + C[/tex]. But if I solve for y(0) = 6, then I get [tex] y = 36(0) + \frac{1}{3}(0)^3 + C[/tex]. But the answer can't be [tex] y = 36y + \frac{1}{3}y^3 + 6[/tex] - can it?! And what is the significance of [tex] 0 < c < \frac{\pi}{2} [/tex] - why is this needed? I've been looking all over my calculus book, but I just don't understand how to do this. I am taking Engineering Mathematics (Kreyzig Book) and I can't help but feel that there is this large gap between this book and my calculus skills.. everything just looks so different.. *sigh* Can anyone help me out? |
| Mar25-06, 06:22 AM | #2 |
Do you know what an independent variable is, and what it means to integrate with respect to that?
| Mar25-06, 06:39 AM | #3 |
No, I'm afraid not. Does it have anything to do with implicit differentiation?
| Mar25-06, 06:47 AM | #4 |
x is your independent variable, y is your dependent.
Go back to your fallacious "integration" of the diff. eq. On your left hand side, you have found the anti-derivative of y'(x) correctly, that is simply y(x). But which variable have you integrated with respect to on your right hand side? The dependent or the independent variable? |
| Mar25-06, 07:04 AM | #5 |
Thank you for telling me about the independent and dependent variable. It now rings a bell.
I just realised that I said differentiation instead of integration. As you can see, I am hopelessly confused.. I have only encountered equations where (for dy/dx) there are x's on the right hand side. I have never encountered equations with y's and x's and, as in this case, only y's. I.. don't really know where to start. What should I be thinking of doing? |
| Mar25-06, 09:05 AM | #6 |
You are right about the discrepancy between what you are trying to do and your calculus skills! Plan to spend a lot of time reviewing calculus.
In the first place, you aren't "differentiating", you are "integrating". And the integral of y with respect to x is not (1/2)y2: y is some function of x and without knowing what function you don't know how to integrate it- that's the whole point of differential equations! Actually, the part you say you are stuck on- that you are given y(0) rather than y(4) is trivial- just use x= 0 instead of x= 4! However, the part that you think you can do is completely wrong. Your equation is y'= 36+ y2. You might see it better if you wrote that as [tex]\frac{dy}{dx}= 36+ y^2[/tex]. Separating into "differentials" [tex]dy= (36+ y^2)dx[/tex]. Now can you see that the right hand side has "dx" rather than "dy"? You can't just treat that as an integral. In this simple example, a "separable" equation in which x and y can be completely separated, however, you can write it as [tex]\frac{dy}{y^2+ 36}= dx[/tex]. Can you integrate that (think "arctan")? Once you've done that integration and have y as a function of x, with the constant of integration, set x= 0 and y= 6 to determine the constant. |
| Mar25-06, 09:30 AM | #7 |
My god. You are a GOD. Thank you SO much. I feel as a mortal would feel when a god demonstrates his powers by parting the sea or something. I am finally liberated from hours of trying and failing to understand my textbook.
I thank you. From the bottom of my heart. You don't know how happy I feel right now! :D So to continue, it becomes [tex] \int \frac{dy}{y^2+6^2} = \int dx [/tex] [tex] \frac{1}{6}arctan\frac{y}{6} + C = x[/tex] Then [tex] C = x - \frac{1}{6}arctan\frac{6}{6} = 0 - \frac{1}{6} . \frac{\pi}{4} = - \frac{\pi}{24} [/tex] But then.. if I do this, I come up with a different answer: [tex] \frac{1}{6}arctan1 = x - C [/tex] [tex] arctan1 = 6x - 6C [/tex] [tex] arctan1 = 6(0) - C [/tex] [tex] C = -arctan1 = - \frac{\pi}{4}[/tex] What am I doing wrong?! Also, if you cannot separate the variables, what do you do? Do equataions that are not separable have a separate name? |
| Mar25-06, 12:10 PM | #8 |
Differential equations that are not separable are called..non-separable. |
| Mar25-06, 01:41 PM | #9 |
| Mar25-06, 08:07 PM | #10 |
No, no, no!! Though I am fairly sarcastic at times, I assure you I was NOT sarcastic this time!! I realise that I did overdo it a little bit, but I really was overwhelmed with joy! You don't know how happy I was to be liberated from hours of frustration... and to be able to solve a question in this awful book for once! I also recognise you from helping me out a few days ago.. And most probably, I will need your help again in the future! (I have a very long and hard term ahead of me..) I don't think I'd be sarcastic, even if i wanted to - and this book has a way of humbling people like me. But seriously, I was, and still am very grateful! :)
As for the 6C.. I thought that anything multiplied with a constant, remains a constant. I've seen this in my calculus book.. Does it not apply in this situation? Though, yes, I now understand that it is that 6C that is the difference between the two versions.. |
| Mar26-06, 08:26 AM | #11 |
I also encountered something new and I'm not sure what to do:
The problem is: [tex] y' = \frac{1-7y-49x}{1+y+7x} [/tex] with [tex] \inline y^2(1)=7 [/tex] using [tex] \inline (y + 7x = v) [/tex] I've managed this so far: [tex] v'-7 = \frac{1-7v}{1+v} [/tex] [tex] v' = \frac{-7(1+v)}{1+v} + \frac{8}{1+v} + 7 [/tex] [tex] \frac{dv}{dx} = \frac{8}{1+v} [/tex] [tex] \int (1 + v) dv = \int 8 dx [/tex] [tex] v + \frac{1}{2}v^2 = 8x + C [/tex] But how do I plug that into [tex] (y = v - 7x) [/tex] to get the constant?! How do I reduce [tex] v + \frac{1}{2}v^2 = 8x + C [/tex] for a single v? |
| Mar26-06, 08:30 AM | #12 |
Assuming you have calculated correctly,
solve for v(x) using the quadratic formula. |
| Mar26-06, 09:34 AM | #13 |
Oh! But... doesn't a quadratic equation have to be in the form ax^2 + bx + c = 0; doesn't it have to equal zero?
How do I do it if it equals 8x? Could you tell me about the 6C = C bit from the previous equation? I'm running into a lot of equations where I have to multiply a constant, and it is very important for me to know whether 6C = C or 6C = 6C (so that if it is 6C = 2, then C = 2/6).. |
| Mar26-06, 09:47 AM | #14 |
As for the "C"-thing:
Different C's are for y-functions with different initial conditions than yours, but fulfilling the same differential equation. C is fixed for a particular solution of the diff. eq. As for the quadratic formula: Write this as: [tex]\frac{1}{2}v^{2}+v+(B-8x)=0 (B=-C)[/tex] That is: [tex]v=-1\pm\sqrt{1-2(B-8x)}[/tex] The constant B is determined from initial conditions. |
| Mar26-06, 10:00 AM | #15 |
I'm sorry, I've suddenly seen that you've made a total mess of evaluating your initial condition earlier. I'll post a reply later.
| Mar26-06, 10:03 AM | #16 |
So, you've got: [tex]\frac{1}{6}arctan(1)=-C\to{C}=-\frac{\pi}{24}[/tex] |
| Thread Closed |
Similar discussions for: Initial Value Problem (with y(0) ?!)
| ODE from Initial Value Problem | Calculus & Beyond Homework | 1 | ||
| initial value problem | Calculus & Beyond Homework | 3 | ||
| initial-value problem | Calculus & Beyond Homework | 12 | ||
