 Quote by heatmover
Hello,
Great discussion. Any references for a similar problem?
Copper pipe is bathed in a hot material.
Copper pipe has cooler water flowing through the pipe.
How to calculate heat flow through the copper pipe to moving water?
Non laminar flow is thought to improve heat transfer to water.
What you are describing here is a unit called a "heat exchanger". The calculations for a heat exchanger can be rather complex. Dealing with the mediums, the temperature difference entering to leaving of both the transfer medium and the product being heated, the materials used in the exchanger, the insulating/transfer values of the tube side and shell sides. For references to this problem try searching for information on "Copper tube heat exchangers."
