| Thread Closed |
On The Quantum Dynamics of Moving Bodies |
Share Thread | Thread Tools |
| Mar26-06, 04:00 AM | #1 |
"On the Quantum Dynamics of Moving Bodies"
may be found in the list under http://federation.g3z.com/Physics This writeup is still at a heuristic level, not mathematically airtight. The major problem, at present, is trying to find where the corresponding theorems *reside* (C*-algebra framework, representation theory or otherwise) -- somewhat analogous to the difficulty faced prior to the discovery of (a?/the?) proper formulation of the Stone-von Neumann theorem. Nonetheless, it's quite interesting, revealing, and has a lengthy discussion on the general issue of how one might generalize the infrastructure of quantum theory so as to enable its safe cohabitation with classical theories, like GR. It was something I originally intended for the 2005 anniversary edition of Annalen (hence the language in the introduction), but it will have to await further resolution of the above issues... There's a nice derivation of the Helmholz conditions in the appendix, which supplements the derivation posed for the field theoretic case ("The Helmholz Conditions and Field Equations", also found in the archive above). Part of the intent is to show the close parallel with the derivation posed in the rest of the paper, leading to the idea that the structure being uncovered in the writeup is simply the non-commutative generalization of Helmholz, itself. It's possible that someone with more mathematically keen eyes may see how to actually produce from this a non-commutative analogue of the derivation in the appendix, within some kind of non-commutative version of the usual jet bundle formalism used for lagrangians, so that the spirit of the rest of the writeup can be captured. Abstract: The combination of the equal-time commutator relatoins [q(t),q(t)] = 0 and 2nd order euqations of motion q''(t) = a(q(t),q'(t)) for a system with configuration coordinates q(t) = (q^1(t),q^2(t),...) imposes compatibility constraints on the dynamics strikingly similar to the Helmholz conditions which -- in classical dynamics -- determine the existence of a Lagrangian and Hamiltonian. Following Hojman and Shepley (1991), we will investigate the consequences of this correspondence, this time without the need to resort to the classical limit. Our focus will be restricted to the special case where the [q,q'] commutators are c-numbers. For closed systems with a finite number of degrees of freedom, this implies the reduction to the combination of a classical subsystem and quantum subsystem, the latter being canonically quantized with respect to a Hamiltonian quadratic in the conjugate momenta and evolving in superselection sectors provided by the former. This includes, as limiting cases, purely classical or purely quantum systems. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: On The Quantum Dynamics of Moving Bodies
| ON THE ELECTRODYNAMICS OF MOVING BODIES by A.EINSTEIN | Special & General Relativity | 16 | ||
| Max distance betw 2 retarding bodies moving towards each other,so that they meet. | Introductory Physics Homework | 1 | ||
| On The Quantum Dynamics of Moving Bodies | General Physics | 0 | ||
| Two Relativistic Moving Bodies | Introductory Physics Homework | 2 | ||
| system of moving bodies | Introductory Physics Homework | 7 | ||
