What is the significance of the ooze wave function and its normalization?
The discussion revolves around the significance of the "ooze" wave function and its normalization within the context of quantum mechanics, particularly focusing on energy probabilities and average energy calculations in a square potential well scenario.
  • Participants explore the meaning of the normalization factor K and its role in ensuring the wave function integrates to one. Questions arise regarding the calculation of probabilities associated with energy measurements and the interpretation of average energy.
There is an ongoing exploration of the normalization process for the wave function, with some participants providing insights into the mathematical relationships involved. Multiple interpretations of energy probabilities and their calculations are being discussed, with no explicit consensus reached.
Participants express uncertainty about the definitions and implications of certain terms, such as the average energy and the relationship between wave functions and energy probabilities. The discussion reflects a mix of understanding and confusion regarding the underlying principles of quantum mechanics.
UrbanXrisis
The following is a "ooze" wafve function:
[tex]\Psi_{ooze} (x,t)=\frac{1}{K} \left( \Psi_1 + \Psi_2+...+\Psi_{1000} \right)[/tex]
1. I am to find the value of K, but I don't even know what it represents. Is K the coefficient to normalize the coefficient to 1?
2. Probability where energy [tex]E_q[/tex] can be observed?
[tex]E_n = \frac{n^2 \pi^2 \hbar^2}{2mL^2}[/tex]
[tex]\sum_{n=1}^q \frac{n^2 \pi^2 \hbar^2}{2mL^2}[/tex]
[tex]\frac{ \pi^2 \hbar^2}{2mL^2} \sum_{n=1}^q n^2[/tex]
3. Then I am to find the average energy predicted to be observed. I am not sure what this even means. I am guessing: [tex]E_{avg} = \frac{n^2 \pi^2 \hbar^2}{2nmL^2}[/tex] ??
I don't know what you're doing at 2, but for 1., yes, it's a normalization factor.
Daniel.
1) A constant factor in front the wavefunction is always for normalization. It can also have a phase, but that's of no physical significance.
2) Ok, from the energies I see this is a square potential well problem. Why are you summing all the energies from [itex]E_1[/itex] to [itex]E_q[/itex]? (And what does it mean?)
You have to find the probability (which is a number between 0 and 1) to measure [itex]E_q[/itex] when you do a measurement of the energy. So what's the general rule for finding the probability of getting a certain result?
3. If you find the probabilities in 2) then I`m sure you can calculate the average.
I know how to find the probability for a wavefunction, but not the probability for energy. For a wavefunction, you multiply the complex conugate of the wavefunction but what about energy? and how does the average energy relate to this?
What do you mean 'I know how to find the probability for a wavefunction'. What [itex]|\Psi|^2[/itex] tells you is the probability density for the position of the particle. The phrase 'probability for a wavefunction' doesn't make sense in this context.
The probability of measuring [itex]E_n[/itex] is:
[tex]P(E_n)=|\langle \Psi_n|\hat H|\Psi\rangle|^2[/tex]
[tex]\langle \Psi_n|\hat H|\Psi\rangle=\int_{-\infty}^{\infty}\Psi_n^*(x,t) \hat H \Psi(x,t)dx[/tex]
Surely something like that should be in your book?
Once you know the probabilities for all the energies, you can calculate the average (also called the expected value, which is misleading). But that's not physics per se, that's probability, or statistics:
[tex]\langle A\rangle=\sum_n a_nP(a_n)[/tex]
how would I find K? I am really stumped by this
K should be such that the wavefunction is normalized.
I
So:
[tex]\int_{-\infty}^{+\infty}|\Psi(x)_{ooze}|^2dx=1[/tex]
Now write out the integrand. You'll get a lot of terms, but note all the cross terms integrate to zero, since the [itex]\Psi_i[/itex] are orthogonal.
[tex]\int \frac{1}{K}\frac{1}{K} \Psi_{1}* \Psi_{1} (x,t)+...+\frac{1}{K}\frac{1}{K} \Psi_{1000}* \Psi_{1000} (x,t)=1[/tex]
[tex]= \frac{1000}{k^2} =1[/tex]
[tex]k=\sqrt {1000}[/tex]
something like that?
Yep. :smile:
so if I was to find the average energy it would be [tex]\frac{1}{1000} E_1 +\frac{1}{1000} E_2 +...+\frac{1}{1000} E_{1000}[/tex] ?
Yes again.
  • · Replies 20 ·
