Thread Closed
What is the different between the max stress and the von mise stress
Share Thread Thread Tools
Mar27-06, 11:48 AM   #1
What is the different between the max stress in a structure and the von mise max stress in the same structure?
Kindly Lorens
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Mar27-06, 12:09 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
I'm not quite sure if I'm answering your question as you want, but:
1. From my hazy recollection, the von Mieses "(max) stress" in a structure is the YIELD criterion of the structure; i.e, if the local stress exceeds that value, plastic flow will occur.
2. Max stress in a structure is simply that: the maximal stress value in the structure.
Clearly, the max stress in the structure must be below the von Mieses yield criterion to ensure that plastic flow does not occur.
Mar27-06, 03:01 PM   #3
But in Fem you often look in to the von miese stress, and you can list the von mises stress for the diffrent nodes ...
Mar27-06, 03:16 PM   #4
Recognitions:
Hmm..but that would surely mean the material has non-uniform properties (and, hence, different yield criteria)?
It is in principle unproblematic of making a non-constant yield stress function. In that case, the requirement is that the local stress does not exceed the local yield criterion.
I'll see if I get someone else to look in on the thread..
EDIT:
As kindly provided by another member, perhaps your problems are resolved by taking a look at:
http://www.engineersedge.com/strength_of_materials.htm
Oct14-10, 09:56 PM   #5
Hi All
I m new here, I have few basic queries, if anyone can clarify on same.
Que1):-For any linear static FEA analysis,w hy do we consider mostly Voin Misses stresses?Why not Principal or any other stresses ?
Que2):-Does Epsilon Values depends on elasticity or Density?
Thread Closed
Thread Tools
Similar Threads for: What is the different between the max stress and the von mise stress
Thread Forum Replies
Vonmises Stress Vs Maximum Principle Stress Mechanical Engineering 6
Stress Introductory Physics Homework 3
Stress-energy tensor of a wire under stress Special & General Relativity 178
compressional stress & shear stress Introductory Physics Homework 1
Stress @ Proportional Limit, Ultimate Stress, Breaking Stress, etc. General Physics 0
