DIY Portable 300V Capacitor Charger
The discussion revolves around the design and construction of a portable 300V capacitor charger, focusing on the conversion of DC to AC using various circuit designs and components. Participants explore different methods, including oscillators and transformers, and share insights on circuit behavior and component interactions.
  • Some participants suggest using a 2N3055 transistor and a resistor for DC to AC conversion, but details on the circuit are unclear.
  • One participant proposes feeding DC through an oscillator tank circuit to generate AC at the oscillating frequency.
  • Another participant questions how to build an oscillator tank circuit or if it can be salvaged from existing electronics.
  • There are suggestions to use a timer chip and transistors to create a simple square wave AC output.
  • A tank circuit is described as consisting of a capacitor and an induction coil, with the frequency of oscillation dependent on the capacitance.
  • Concerns are raised about the limitations of using a tank circuit with DC, as it may not effectively convert DC to AC without additional components.
  • Some participants discuss the concept of pulsating DC and its potential to create an alternating electromagnetic field, suggesting that flip flops could be used to generate such pulsations.
  • A participant mentions the Wein Bridge Oscillator as a reliable sine wave oscillator, noting its predictable gain and feedback network requirements.
Participants express differing views on the effectiveness of various methods for converting DC to AC, with no consensus reached on the best approach. Some participants challenge the feasibility of using tank circuits with DC, while others explore the potential of oscillators and feedback circuits.
Participants highlight the importance of component specifications, such as resistance values and feedback mechanisms, which may affect circuit performance. There are also mentions of potential issues with high-frequency pulses and the behavior of coils in relation to filtering.
Individuals interested in DIY electronics, capacitor charging circuits, and oscillator design may find this discussion relevant.
Shep
I am going to build a small portable 300V capacitor charger.
I have a 9<->230V transformer and as a powersource i will use a 9v battery.
The thing i do not know is how to convert DC-AC that is needed. I found a circuit where they used a 2N3055 transistor and a resistor but i do not remember exactly how it was done.
After the transformer i will use a bridge rectifier to convert it back to DC again.
/Shep
What if you feed the DC through an Oscillator tank circuit? The output would then be AC at the oscillating frequency setting of the tank, yes?
Well, how do i build a oscillator tank circuit?
Or can it be salvaged from some electronics?
You can cop out, go to Target and buy a 12V inverter.
Depending on how 'nice' you want the AC to be, a really simple solution is to use a timer chip and transistors to simply switch the current back and forth in a square wave.
A tank circuit is nothing more than a capacitor and an induction coil (an induction coil is simply a coil of wire). By changing the capacitance of the capacitor (if it is a varible capacitor), you change the frequency at which the current will oscillate.
The induction coil itself can be used as the second leg of a tranformer (which is nothing more than two induction coils side by side), in order to induce the current into the tank circuit.
Cont... Sorry, clicked the wronge button...
Or the induction coil can be used to induce the power from the tank circuit by being the primary leg of a transformer. For your case, you would atach the dc power leads to the tank circuit (one lead on one side, the other lead on the other side), and then induce the alternating current from the induction coil.
Think Safe!
A tank circuit will not convert a direct current to AC. If you connected a tank circuit to a DC source, the inductor, if no resistor was in series with it, would short the DC source. If you did have a resistor to limit the current through the coil, then you would simply have a direct current flowing through the coil. No current would flow through the capacitive branch when the capacitor is fully charged. Effectively, with direct current, an inductor has 0 reactance and a capacitor has infinite reactance.
Inductive Reactance
[tex]X_l=2\pi fl[/tex]
Capacitive Reactance
[tex]X_c=\frac{1}{2 \pi fc}[/tex]
Both of these are measured in ohms.
When dealing with RCL circuits, the total impedance is given by:
[tex]Z=\sqrt{R^2+X_t^2}[/tex]
[tex]X_t=X_l-X_c[/tex]
At the resonant frequency,
[tex]f_r=\frac{1}{2\pi\sqrt{LC}}[/tex]
the total reactance is 0 and this means in a series RCL circuit that the total impedance is at it's lowest.
A parallel RCL circuit operating at the resonant frequency will have maximum impedance.
The frequency of a DC signal is 0 Hz so reactance doesn't come into play. Now if you're talking about pulsating DC, that's a different matter all together.
Yes, thank you. Because the pulsating dc would in effect expand and collapse the electromagnetic field that is being generated onto the coil whereas a constant dc source would only create it, not collapse it, and it is the creating and collapsing of the electromagnetic field combined that produces the ac. Therefore, the next step (or prior step), would be to generate pulsating dc from constant dc. It would be at this point where the pulsating dc polarity would be reversed with each pulsation, right? Could this pulsating dc be accomplished by using flip flops?
Pulses can be generated with any number of simple feedback circuits. The problem is that with high-frequency pulses, the coil will probably act as a low-pass filter, and smooth them out instead of treating them as pulses.
/Shep
This may be of interest to you.
http://www.angelfire.com/80s/sixmhz/flyback.html
Thanks for the link. I have attached a file were i have changed the circuit a bit. Do you think this is possible?
If the resistance on the resistor is right then the transistor do not get enough ampere on the base to stay on when current goes trough the primary. Transistor turns off.
When the primary do not conduct because the transistor if off there is enough ampere going to the base to turn the transistor on.
This would result in some kind of a square wave i think.
From practical experience, the best sine wave oscillator (aside from monolithic packages) is the Wein Bridge Oscillator.
You can use any type of gain device (transistor amp, op amp, etc.) but you need a feedback network of the "lead-lag" type.
The reason why i like this oscillator is that the gain required is predictable (around 3), because the feedback network's attenuation factor is always aroudn 1/3.
Research Wein Bridge Oscillators, they are fundamentally easy to understand and are a good starting point before you get into more advanced oscillators.
For Square waves, best bet is to go with a 555 Timer.
  • · Replies 26 ·
