Thread Closed
Gauss's Divergance Theorem and Stokes's Theorem
Share Thread Thread Tools
Dec26-03, 11:27 AM   #1
Arrow
I've been reading the text: Electricity and Magnetism, by Purcell.
I understand about the integral forms describing the electric field, but when trying to answer questions at the end of the chapter on Gauss's and Stokes's therorems I have not been able two. These two theorems supposedly transform the integral equations that describe an electric field into differential equations, yet there are still integrals in the equations:
Gauss:
[tex]Integrate[F*da,over surface]=Integrate[div F*dv,over volume][/tex]
[tex]div F=4\pi\rho, del^2*potential=-4\pi\rho[/tex]
Stokes:
[tex]Integrate[F*ds,over circ.]=Integrate[curl F*da,over surface][/tex]
[tex]del X A[/tex]
Questions:
1. I'm having trouble with looking at field lines and judging if div F=0 (or not zero) or curl F=0 (or not zero)
2. How to calculate flux/volume for Gauss problems. I see in the book they use the midpoint. Or flux/area for Stokes problems. Why do the choose the midpoint?
3. Also would someone explain the sidways derivative of the curl, I don't understand why it is the way it is.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Dec30-03, 08:47 PM   #2
Questions:
I found this helpful for curl. Imagine water flowing in a rectangular aquaduct. The water all moves at the same speed as you cross the aquaduct. This flow has no curl.
Now imagine an aquaduct where the water flows faster the further it is from the bank you're standing on. As you move perpendicular to the flow direction, the flow rate gets faster. This flow has a nonzero curl. Place a stick perpendicular to the flow, the far edge wants to move faster than the near end making the stick want to turn.
Now look at the math for curl. If the flow is in the x direction then the curl is given by the derivatives dv/dy and dv/dz. That is the velocity v is changing when you move perpendicular to the flow direction.
Thread Closed
Thread Tools
Similar Threads for: Gauss's Divergance Theorem and Stokes's Theorem
Thread Forum Replies
Stokes's Theorem Calculus & Beyond Homework 11
greens theorem and cauchy theorem help Calculus & Beyond Homework 4
Gauss' Theorem/Stokes' theorem Advanced Physics Homework 2
Flux and Gauss's theorem Classical Physics 2
Gauss's Theorem problem Calculus & Beyond Homework 1
