Force = mass x acceleration and related subject
The discussion revolves around calculating the force or thrust required to lift a specific mass, particularly in the context of designing a hovercraft capable of supporting a person's weight. The subject area includes concepts of force, mass, and acceleration, particularly in relation to gravitational effects.
  • Participants explore the basic equation f=mg for lifting an object at constant velocity and discuss the implications of acceleration. Questions arise regarding the specifics of the lifting scenario, such as whether the object is lifted at constant velocity or with acceleration, and the relevance of gravitational acceleration.
The discussion is active, with participants providing insights into the calculations needed for thrust based on weight. Some guidance has been offered regarding the necessary thrust to lift a given weight, but there remains a need for clarification on the specific conditions of the lifting scenario.
Participants note the ambiguity in the original question regarding the lifting conditions, emphasizing the need for more detailed information to provide accurate calculations. There is also mention of unit conversions and the distinction between weight and mass in the context of the problem.
magic_ghost
Hello,
Simple question.
Is there an equation or set of equations which allow me to calculate how much force/thrust is needed to lift a certain amount of mass or weight?
Daniel
If you are lifting it at a constant velocity upwards, then just use f=mg. So you use g as your acceleration, since it's the "acceleration due to gravity".
EDIT: If you are accelerating something upward, then just add the acceleration upward to g.
magic_ghost said:
Hello,
Simple question.
Daniel
Unfortunately, this is too vague to answer. It depends what you mean...Is the object lifted at constant velocity? Is it accelerating? Is the object lifted near the surface of the Earth? And on and on...
With a more detailed situation, we could give you explicit formula.
So to be more specific,
I am thinking of making a small hovercraft which can support the weight of one person (i.e. 140 pounds).
I know I will need a fan to produce the thrust but in order to know how powerfull the fan needs to, I will need to know how much thrust is required to lift 140 pounds.
Thankyou
Thankyou
Working in SI units, the thrust you need to barely lift the person is simply (mass of hovercraft + mass of the person) times 9.80 m/s^2. A pound is really a unit of weight (not mass) so if the person plus hivercraft weight one thousand pounds, you need one thousand pounds of thrust, minimum.
  • · Replies 25 ·
  • · Replies 21 ·
