buoyant force problem
by kellyneedshelp
Tags: buoyant, force
kellyneedshelp
kellyneedshelp is offline
#1
Apr9-06, 11:35 AM
P: 41
Hi, I am having some trouble with the following question:
You (mass 70.1 kg) decide to take off--literally--with a helium balloon of mass 31.6 kg. The densities of air and helium are air = 1.321 kg/m3 and helium = 0.179 kg/m3. What volume of helium is needed to levitate you and the balloon?
I think that you use the buoyant force equations, but I am not sure how. I tried doing it like this:
F(buoy)=density(fluid)*V'*g or
(101.7*9.81)=(1.321*V'*9.81) and solved for V' and got
V'=76.987 m^3
but this is not correct.
I cannot figure out how to do this problem, any help would be appreciated.
Thanks!!
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
Hootenanny
Hootenanny is offline
#2
Apr9-06, 11:50 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
If we take the equation which you stated;
[tex]F_{b} = \rho V g[/tex]
The 'thing' that is creating the bouyant force is the difference between the relative densities of the fluids hence in your case;
[tex]F_{b} = ( \rho_{air} - \rho_{helium} )Vg[/tex]
-Hoot
arildno
arildno is offline
#3
Apr9-06, 11:53 AM
Sci Advisor
HW Helper
PF Gold
P: 12,016
First, you must state the total weight of your system:
[tex]W=W_{person}+W_{balloon}+W_{helium}[/tex]
Note that your unknown volume appears in [itex]W_{helium}[/tex]
Assuming that you and the balloon material contributes only negligibly to the total volume of the system, you can now find what the volume must be by equating this total weight with the buoyant force (which is the net pressure force needed to keep a volume V of air floating in..the air).
andrevdh
andrevdh is offline
#4
Apr9-06, 11:59 AM
HW Helper
P: 1,446
Try adding the weight of the helium in the balloon to the lefthand of your equation, the mass of the balloon probably do not include this additional weight
[tex]m_{helium}g=\rho_{helium} Vg[/tex]
kellyneedshelp
#5
Apr9-06, 04:43 PM
P: 41
so the volume must be 89.05 m^3, thanks everyone!
Register to reply
Related Discussions
Buoyant Force Problem Introductory Physics Homework 3
buoyant force problem. Introductory Physics Homework 9
Buoyant force problem. Plz help. Introductory Physics Homework 2
Buoyant force problem Introductory Physics Homework 1
Buoyant Force Introductory Physics Homework 9
