Register to reply
Stuck on probability question
by orchdork89
Tags: probability, stuck
Share this thread:
orchdork89
#1
Apr12-06, 01:52 PM
P: 2
"The probability that a seed will sprout is 3/4. If 7 seeds are planted, find, to the nearest ten-thousandth, the probability that at least 5 will sprout."
The answer is .7564, but I don't know how to get there. I tried (3/4^5) + (3/4^6) + (3/4^7), but that doesn't work. Neither does (3/4*5) + (3/4*6) +(3/4*7)... am I overthinking the question, or is there a formula involved that I don't know?
Thanks!
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
Galileo
#2
Apr12-06, 01:59 PM
Sci Advisor
HW Helper
Galileo's Avatar
P: 2,002
This is a binomial distribution problem.
You have n seeds. What is the probability that exactly k seeds will sprout?
Take into account that the specification of which will sprout and which don't is not important.
arildno
#3
Apr12-06, 02:17 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Now, remember that the events of whether a seed sprouts or not is independent of whether the other seeds sprouts.
Also, the probability that a single sprout EITHER sprouts OR not sprouts is obviously:
[tex]1=\frac{1}{4}+\frac{3}{4}[/tex]
where 1/4 is the probability of non-sprouting, 3/4 the probability of sprouting.
Suppose we only have TWO seeds
Consider the following identity:
[tex]1=(\frac{1}{4}+\frac{3}{4})^{2}=\frac{1}{4}*\frac{1}{4}+2*\frac{1}{4}*\ frac{3}{4}+\frac{3}{4}*\frac{3}{4}[/tex]
Now, the first term, 1/4*1/4=1/16 is clearly the probability that neither of the two seeds sprouts, the second term, 2*1/4*3/4=6/16 must be the probability that only one of the seeds sprouts, whereas the last term, 3/4*3/4=9/16 is the probability that BOTH sprout.
Considering this, how could you set up a similar scheme for the probabilities for 7 seeds?
HallsofIvy
#4
Apr13-06, 09:43 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,344
arildno, that sounds much more complicated than necessary!
Here's how I would do it:
What is the probability that all 7 will sprout? You should know enough to argue that, assuming the sprouting of one seed is independent of the others, you just multiply the probabilities: (3/4)(3/4)(3/4)(3/4)(3/4)(3/4)(3/4)= (3/4)7.
What is the probability that exactly 6 will sprout? Well, what is the probability that the first 6 sprout but the last doesn't. Again it is the individual probabilities multiplied together: (3/4)(3/4)(3/4)(3/4)(3/4)(3/4)(1/4)= (3/4)6. But we're not done: what about the first 5 sprout, the sixth doesn't, and the seventh does sprout? Since multiplication is commutative, that will be again exactly (3/4)6 and, in fact, for any of the 7!/(6!1!)= 7 different ways that could happen (Taking "S" to mean that seed sprouts and "N" to mean it doesn't, we ould have SSSSSSN, SSSSSNS, SSSSNSS, SSSNSSS, SSNSSSS, SNSSSSS, or NSSSSSS, 7 possible orders) it will be (3/4)[/sup]6[/sup](1/4) for each and so the probability exactly 6 seeds sprout is 7(3/4)[/sup]6[/sup](1/4).
What about 5 sprounting and 2 not? Hopefully, you can see now that the probability of a particular order but any order, is (3/4)5(1/4)2. Now how many different orders can we have where 5 sprout and 2 do not? How many different order for the letters SSSSSNN are there? This is where the "binomial coefficient comes in.
Once you have found the probability that exactly 7, exactly 6, and exactly 5 seed sprout, add them.
arildno
#5
Apr13-06, 01:18 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Why is [itex]1=1^{7}[/itex] a complicated identity?
Okay, I'll admit I have an unreasonable fondness for the expression..
HallsofIvy
#6
Apr13-06, 03:40 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,344
Quote Quote by arildno
Well, now that you put it that way! It did occur to me when I typed that that you might well consider what I did too complicated!
orchdork89
#7
Apr14-06, 11:42 AM
P: 2
ummm... please take into account that I am 16 and stupid
arildno
#8
Apr14-06, 11:46 AM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Well, did you understand how we might find the probabilities of events in the case of two seeds?
For example, referring to my earlier post:
Of two seeds, what must be the probability that AT LEAST one seed sprouts?
sparsh
#9
Apr21-06, 12:02 PM
P: 51
this might help
by the binomial distribution
we have to consider the prob of either 5 or 6 or 7 sproutings
Thus
7C5 (3/4)^5 (1/4)^2 + 7C6 (3/4)^6 (1/4) + 7C7 (3/4)^7
C stands for combination (hope you understand the binomial notation)
Cheers
Sparsh
Register to reply
Related Discussions
Probability Problem- im still stuck Calculus & Beyond Homework 2
Stuck on question Introductory Physics Homework 1
Stuck on question Introductory Physics Homework 3
Stuck on this probability problem... Introductory Physics Homework 1
