Spice simulation help
by ranger
Tags: simulation, spice
ranger
ranger is offline
#1
Apr12-06, 08:29 PM
PF Gold
ranger's Avatar
P: 1,686
I'm currently learning spice. I need help with a very simple circuit.
Here is the netlist:
Example netlist
v1 1 0 dc 15
r1 1 0 2.2k
r2 1 2 3.3k
r3 2 0 150
.end
When I run it in spice(2g6) I get:
******* 12/04/10 ********  SPICE 2G.6    15/3/83 ******** 21:24:57 ****
**** EXAMPLE NETLIST
****     INPUT LISTING                    TEMPERATURE =   27.000 DEG C
V1 1 0 DC 15
R1 1 0 2.2K
R2 1 2 3.3K
R3 2 0 150
*ERROR*:  .END card missing
Input deck (file) contains no data.
The tutorial I am using says to do exactly that, but yet I get this error. As you can see I have .end in my netlist. Whats wrong?
--thank you.
Phys.Org News Partner Engineering news on Phys.org
Fiber-optic microscope will help physicians detect cancer, diseases at early stages
Wind tunnel tests support improved aerodynamic design of B61-12 bomb
Smart sensor technology to combat indoor air pollution
chroot
chroot is offline
#2
Apr12-06, 08:36 PM
Emeritus
Sci Advisor
PF Gold
chroot's Avatar
P: 10,424
Is it possible your version of spice is case-sensitive? Have you tried using .END instead of .end?
- Warren
ranger
ranger is offline
#3
Apr12-06, 08:56 PM
PF Gold
ranger's Avatar
P: 1,686
I still get the same error with .END
Its weird though, doing a simple RC example netlist:
Basic RC circuit
r 1 2 1.0
*l 1 2 1.0
c 2 0 1.0
vin 1 0 pulse (0 1) ac 1
.tran 0.1 7.0
*.ac dec 10 .01 10
.plot tran v(2) i(vin)
*.plot ac vdb(2) xlog
.end
The simulation goes about just fine.
berkeman
berkeman is offline
#4
Apr12-06, 10:24 PM
Mentor
berkeman's Avatar
P: 39,575
Example netlist
v1 1 0 dc 15
r1 1 0 2.2k
r2 1 2 3.3k
r3 2 0 150
.end
Looks like it should work. I'll run it tomorrow at work (I'm at home now) to see what happens. In the mean time, are there any hidden characters maybe in the file? Some goofy ctrl-oops character that crept in?
PS -- Very cool links in your footer. I'll have to spend some time browsing those pages more....
ranger
ranger is offline
#5
Apr13-06, 08:47 AM
PF Gold
ranger's Avatar
P: 1,686
Unfortunately they arent any. At first I simply copied the netlist, but after I typed them out and saved them in a new file, I still get the same error.
berkeman
berkeman is offline
#6
Apr13-06, 10:30 AM
Mentor
berkeman's Avatar
P: 39,575
You text file runs fine in my MicroCAP8 SPICE simulator. I copied your text from your post and pasted it into an input file, and ran a transient analysis. MC8 ended up with this file after the transient analysis:
Example netlist
v1 1 0 dc 15
r1 1 0 2.2k
r2 1 2 3.3k
r3 2 0 150
.TRAN 2e-008 1u 0
.TEMP 27
.PLOT TRAN v(1) v(2) 0,37.5
.end
ranger
ranger is offline
#7
Apr13-06, 10:43 AM
PF Gold
ranger's Avatar
P: 1,686
Using your netlist with .TRAN, etc. I still get the same error. Mayb there us something wrong with the program?
I got the program from here (towards the bottom of the page).
V1 1 0 DC 15
R1 1 0 2.2K
R2 1 2 3.3K
R3 2 0 150
.TRAN 2E-008 1U 0
.TEMP 27
.PLOT TRAN V(1) V(2) 0,37.5
Its like it refuses to read .END
What OS are you running SPICE on? Is MicroCAP8 SPICE free?
berkeman
berkeman is offline
#8
Apr13-06, 10:48 AM
Mentor
berkeman's Avatar
P: 39,575
I've run MicroCAP on NT and XP. This current MC8 installation is running on my XP PC. I don't know if there is a lower-cost student version of MicroCAP, but you could check Spectrum Software's website:
http://www.spectrum-soft.com/index.shtm
Have you looked in the Help menu of your program to see if it requires something special for the .end statement? Does it come with any sample files? Do you have any friends who are also using that program?
ranger
ranger is offline
#9
Apr13-06, 10:55 AM
PF Gold
ranger's Avatar
P: 1,686
There is no help file, all I was told to download were three files (no help or samples). All of my friends are using multisim instead :)
I've found a sample netlist (elsewhere):
Basic RC circuit
r 1 2 1.0
*l 1 2 1.0
c 2 0 1.0
.tran 0.1 7.0
*.ac dec 10 .01 10
.end
SPICE can simulate this circuit though.
pervect
pervect is offline
#10
Apr13-06, 02:26 PM
Emeritus
Sci Advisor
P: 7,433
Try adding an .op card to your first netlist. You didn't really instruct the program to do an analysis, that might be the problem.
ranger
ranger is offline
#11
Apr13-06, 03:00 PM
PF Gold
ranger's Avatar
P: 1,686
Quote Quote by pervect
Example netlist
V1 1 0 DC 15
R1 1 0 2.2K
R2 1 2 3.3K
R3 2 0 150
.end
.op
Output:
******* 13/04/10 ********  SPICE 2G.6    15/3/83 ******** 15:55:19 ****
**** MULTIPLE DC SOURCES
V1 1 0 DC 15
R1 1 0 2.2K
R2 1 2 3.3K
R3 2 0 150
.END
****     SMALL SIGNAL BIAS SOLUTION       TEMPERATURE =   27.000 DEG C
 NODE   VOLTAGE     NODE   VOLTAGE
(  1)   15.0000    (  2)    0.6522
    VOLTAGE SOURCE CURRENTS
    NAME       CURRENT
    V1       -1.117E-02
    TOTAL POWER DISSIPATION:   1.67E-01 WATTS
         JOB CONCLUDED
         TOTAL JOB TIME            0.01
That did the job! It works. Its funny how the guy that wrote the tutorial didnt mention this. What is .op for pervect? Thanks.
chroot
chroot is offline
#12
Apr13-06, 05:03 PM
Emeritus
Sci Advisor
PF Gold
chroot's Avatar
P: 10,424
I suspect that you may actually need a newline character after the .end.... i.e., the last line of the file should be blank. Worth a try, yes?
.op runs an operating-point (bias point) analysis.
- Warren
ranger
ranger is offline
#13
Apr13-06, 05:29 PM
PF Gold
ranger's Avatar
P: 1,686
Quote Quote by chroot
- Warren
That newline did the trick.
******* 13/04/10 ********  SPICE 2G.6    15/3/83 ******** 18:27:58 ****
V1 1 0 DC 25
R1 1 0 2.2K
R2 1 2 7.3K
R3 2 0 150
.END
(  1)   25.0000    (  2)    0.5034
    NAME       CURRENT
    V1       -1.472E-02
    TOTAL POWER DISSIPATION:   3.68E-01 WATTS
         JOB CONCLUDED
         TOTAL JOB TIME            0.00
It still says that .end is missing. But the simulation goes through though.
Register to reply
Related Discussions
Spice models Electrical Engineering 0
spice model Electrical Engineering 3
Spice Sucks? Electrical Engineering 11
SPICE internals Electrical Engineering 6
