Register to reply
Rowspace and kernel
by UrbanXrisis
Tags: kernel, rowspace
Share this thread:
UrbanXrisis
#1
Apr18-06, 06:23 PM
P: 1,200
[tex]A = \left(\begin{array}{cccc}-1 &6&5&9 \\ -1&0&1&3 \end{array}\right)[/tex]
Find orthonormal bases of the kernel, row space.
To find the bases, I did reduced the array to its RREF.
[tex]A = \left(\begin{array}{cccc}1 & 0&-1&-3\\ 0&1&2/3&1 \end{array}\right)[/tex]
Then the orthonormal bases would just be that divided by the length.
[tex]||v_1||=\sqrt{1+1+3^2}=\sqrt{11}[/tex]
[tex]||v_2||=\sqrt{1+(2/3)^2+1}=\sqrt{2.44444}[/tex]
so that means, the orthonormal bases would be:
[tex]A = \left(\begin{array}{cccc} \frac{1}{ \sqrt{11}} & 0&\frac{-1}{ \sqrt{11}}&\frac{-3}{ \sqrt{11}} \\0 & \frac{1}{ \sqrt{2.44444}} & \frac{.66666}{ \sqrt{2.44444}} &\frac{1}{ \sqrt{2.44444}}\end{array}\right)[/tex]
what exactly is the orthonormal bases of the kernel?
Also, isnt the row space the same as the vectors of the bases?
I think I also did something wrong in my calculations
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
0rthodontist
#2
Apr18-06, 06:47 PM
Sci Advisor
P: 1,253
If you are looking for an orthonormal basis, one thing to check is that your basis actually is orthogonal. The basis you have found for the row space is not orthogonal.
Given an arbitrary basis for a vector space, do you know how to construct an orthogonal basis for it via the Gram-Schmidt process?
UrbanXrisis
#3
Apr19-06, 12:01 AM
P: 1,200
is what i did above the orthonormal row space? that is wrong as well, i dont know why.... however:
using the Gram-Schmidt process, i still get an error:
[tex]A = \left(\begin{array}{cccc}-1 &6&5&9 \\ -1&0&1&3 \end{array}\right)=\left(\begin{array}{cc}W_1 &W_2 \end{array}\right)[/tex]
want to find an orthonormal basis [tex]R={U_1 ,U_2}[/tex]
[tex]U_1=\frac{W}{||W_1||}[/tex]
[tex]||W_1||=\sqrt{11}[/tex]
[tex]U_1=\frac {\left(\begin{array}{cccc}-1 &6&5&9 \end{array}\right)}{\sqrt{11}}[/tex]
[tex]U_2=\frac{W_2-<W_2 , U_1 > U_1}{||W_2-<W_2 , U_1 > U_1||}[/tex]
where [tex]W_2=\left(\begin{array}{cccc} -1&0&1&3 \end{array}\right)[/tex]
[tex]U_1=\left(\begin{array}{cccc}-1/\sqrt{11} &6\sqrt{11}&5\sqrt{11}&9\sqrt{11} \end{array}\right)[/tex]
is the the correct set up to get an orthonormal basis?
Also, to get an orthonormal row space, what would I have to do?
0rthodontist
#4
Apr19-06, 07:26 AM
Sci Advisor
P: 1,253
Rowspace and kernel
A is not equal to (W1 W2). W1 and W2 are a basis for the row space of A, they are not equal to A when written like that because they are horizontal.
It looks like the method you have set up to find U1 and U2 is correct. What do you mean an "orthonormal row space"? You can find an orthonormal _basis_ U1, U2 for the row space just by finding the vector U2 according to the formula you've set up.
UrbanXrisis
#5
Apr20-06, 12:36 PM
P: 1,200
I typed my W1 and W2 vectors wrong. W1 is supposed to represent the vector (-1 6 5 9) and W2 = (-1 0 1 3)
What do I get when I find U1 and U2? Is U1 and U2 the row space? or is U1 an U2 the orthonormal basis?
Register to reply
Related Discussions
The heat kernel Differential Equations 3
Dimension of column- and rowspace Calculus & Beyond Homework 1
What is the kernel of such a linear map Calculus & Beyond Homework 10
The Kernel of Z (mod 24) X Z (mod 81) Calculus & Beyond Homework 16
Image and kernel of T^n Linear & Abstract Algebra 3
