Understanding the Differences: CMDA vs TDMA in Cellphone Architectures
  • Thread starter Thread starter damgo
The discussion clarifies the technical differences between CDMA (Code-Division Multiple Access) and TDMA (Time-Division Multiple Access) in cellphone architectures. CDMA utilizes spread spectrum multiplexing, allowing multiple signals to occupy the same channel by encoding them with unique pseudo-random sequences. In contrast, TDMA allocates distinct time slots for each channel, which can lead to inefficiencies during intermittent traffic. The conversation also highlights that while Sprint and Verizon use CDMA, they are not cross-compatible with TDMA systems like GSM.
  • Understanding of CDMA (Code-Division Multiple Access)
  • Familiarity with TDMA (Time-Division Multiple Access)
  • Knowledge of multiplexing techniques
  • Basic concepts of cellphone network architectures
  • Research the technical specifications of CDMA and TDMA systems
  • Explore the implications of multiplexing techniques on network efficiency
  • Learn about statistical time division multiplexing and its advantages
  • Investigate the compatibility issues between different cellphone architectures
This discussion is beneficial for telecommunications engineers, network architects, and anyone interested in understanding the operational differences between CDMA and TDMA in mobile networks.
damgo
[SOLVED] CMDA vs TDMA
These are the two cellphone architectures... Sprint uses CDMA (code-division multiplexing) and everyone else uses TDMA (time-division), including the international GSM standard.
My question is, doesn anyone know what the technical difference between the two is? How do they stack up? Can you give any good refs/links? Thanks,
damgo
Computer science news on Phys.org
CDMA (Or "spread spectrum") A form of multiplexing where the transmitter encodes the signal using a pseudo-random sequence which the receiver also knows and can use to decode the received signal. Each different random sequence corresponds to a different communication channel.
Taken from; http://wombat.doc.ic.ac.uk/foldoc/foldoc.cgi?code+division+multiplexing
TDM A type of multiplexing where two or more channels of information are transmitted over the same link by allocating a different time interval ("slot" or "slice") for the transmission of each channel. I.e. the channels take turns to use the link. Some kind of periodic synchronising signal or distinguishing identifier is usually required so that the receiver can tell which channel is which.
TDM becomes inefficient when traffic is intermittent because the time slot is still allocated even when the channel has no data to transmit. Statistical time division multiplexing was developed to overcome this problem.
Taken from; http://wombat.doc.ic.ac.uk/foldoc/foldoc.cgi?time+division+multiplexing
Here is a rather lengthy PDF (over 100 pages) that has a few pages you might find interesting (In chapter two, I believe);
http://scholar.lib.vt.edu/theses/available/etd-05022000-15590055/unrestricted/CDM_FO_MEMS.pdf
i think verizon uses cdma too.
but that doesn't mean that there cross compatable bacause there not.
  • Sticky
9K
  • · Replies 62 ·
13K
  • · Replies 75 ·
10K
