The Equivalence of Mass and Energy
The discussion revolves around a problem involving the collision of an electron and a positron, each with a mass of 9.11 x 10-31 kg, resulting in the production of electromagnetic radiation. Participants are exploring the energy calculations associated with this scenario, particularly in the context of relativistic effects.
  • Mixed
  • Participants discuss the application of the formula E=mc2 and question whether it applies in this scenario, especially considering the velocities involved. There is mention of using the Lorentz factor (gamma) for calculating total energy, leading to discussions about the correct approach for moving masses and the implications of kinetic energy in the context of pair production.
The conversation is ongoing, with various interpretations of the energy calculations being explored. Some participants have offered guidance on the use of gamma in the energy equation, while others are questioning the assumptions made regarding the velocities of the particles and the energy required for pair production.
There are references to classroom teachings about pair production and the minimum energy required for particle creation, which may influence participants' understanding and assumptions in this discussion. The complexity of relativistic effects on energy calculations is also a point of contention.
BoogieL80
I was working on the following problem:
An electron and a positron each have a mass of 9.11 x 10-31 kg. They collide and both vanish, with only electromagnetic radiation appearing after the collision. If each particle is moving at a speed of 0.30c relative to the laboratory before the collision, determine the energy of the electromagnetic radiation.
I feel like I'm missing something basic here. I know the formula is E=mc2. However my webassign says my answer is wrong. Am I wrong to assume that the mass is 2*9.11e-31? Also don't I just multiply 0.30*c2?
No. The total energy is [itex]E = \gamma m c^2[/itex]. Only if a particle is at rest does E= mc^2.
I'm sorry. Why are you using gamma in that equatin?
[tex]\gamma = \frac{1}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
So the full equation then becomes;
[tex]E = \frac{m_{0}c^2}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
The gamma is used as a 'shortend' verson of the equation.
~H
Thank you.
Incidentally we were studying pair production and my physics teacher claimed u simply use e = 2mc^2 regardless of the velocity.
This is valid since the minimum amount of energy required to produce a pair of particles is the amount of energy equivilant to their rest mass. Any additional energy will be in the form of kinetic energy. If two particles are produced with zero kinetic energy then the formula becomes;
[tex]v = 0 \Rightarrow E = \frac{m_{0}c^2}{\sqrt{1-\frac{0^2}{c^2}}}[/tex]
[tex]E = \frac{m_{0}c^2}{\sqrt{1}} = E = m_{0}c^2[/tex]
~H
Yes, but you would be dealing with moving masses here. So, [itex]E = 2\gamma m_0 c^2[/itex] would be right.
Not if you were calculating the minimum energy required to produce a pair of particles.
~H
That can't be right. If you shoot an electron and a positron at 0.99c, the gamma rays emitted will have more energy than if they were initially at rest.
Apologise people, I didn't read the "regardless of velcoity" bit. My mistake.
~H
~H
Oh, but how does [itex]\gamma mc^2[/itex] take care of the two particles here(electron and positron)?
You have to use this for each particle. So total energy = twice that if the two are moving at the same speed.
As I said above, I misread part of the question. But I do not understand what you are asking here?
~H
