How Does the General Solution of a Second-Order Differential Equation Look?
The general solution of the second-order differential equation v" + ë^2v = [-WL/(2EI)]x + [W/(2EI)]x^2 is derived using the method of undetermined coefficients. The homogeneous solution is v_h(x) = Acos(ëx) + Bsin(ëx), where A and B are constants determined by initial conditions. The particular solution is v_p(x) = (W/2ë^2EI)x^2 - (WL/2ë^4EI)x - (W/4ë^2EI). The complete solution combines both parts: v(x) = Acos(ëx) + Bsin(ëx) + (W/2ë^2EI)x^2 - (WL/2ë^4EI)x - (W/4ë^2EI).
  • Understanding of second-order differential equations
  • Familiarity with the method of undetermined coefficients
  • Knowledge of homogeneous and particular solutions
  • Basic proficiency in solving characteristic equations
  • Study the method of undetermined coefficients in detail
  • Learn about the Laplace transform for solving differential equations
  • Explore applications of second-order differential equations in physics
  • Investigate numerical methods for solving differential equations
Students and professionals in mathematics, engineering, and physics who are looking to deepen their understanding of second-order differential equations and their applications.
radwa
will you please help
where ë^2= PE/I
P, E, I, W are constants;
how will the general solution of this equation be
v(x)=Acosëx + Bsinëx + (W/2P)*((x^2)-Lx-2/ë^2)
This is a linear, non-homogeneous, differential equation with constant coefficients. A standard way of solving these is to first look at the corresponding homogeneous equation. In this case that is
v" + ë2v = 0. Such equations typically have exponential (or related)solutions. If you try v= ekx here, v'= k ekx and v"= k2ekx so the equation becomes (k2e+ ë2)ekx= 0. Since an exponential is never 0, we must have k2+ ë2= 0. The solutions to that equation are k= ëi and -ëi. Two independent solutions to the differential equation are eëix and e-ëix but it is simpler to use eëix= cos(ëx)+ i sin(ëx).
The general solution to the homogeneous equation is
v(x)= C1cos(ëx)+ C2 sin(ëx).
Now "look for" a solution to the entire equation- Since the "right hand side", [-WL/(2EI)]x + [W/(2EI)]x2, is a quadratic, try a solution of the form v(x)= Ax2+ Bx+ C. v'= 2Ax+ B and v"= 2A. The equation becomes 2A+ ë2(Ax2+ Bx+ C)= ë2Ax2+ ë2Bx+ 2A+ ë2C= [-WL/(2EI)]x + [W/(2EI)]x2. Equating coefficients of like powers, ë2A= W/(2EI), ë2B= -WL/(2EI), and 2A+ ë2C= 0.
After solving for A, B, C, add that to the solution to the homogeneous equation: v(x)= C1cos(ëx)+ C2 sin(ëx)+ Ax2+ Bx+ C, the solution you give.
Solving linear differential equations with constant coefficients is covered in any basic text on differential equations.
Sure, I would be happy to help you with this second-order differential equation. To solve this equation, we can use the method of undetermined coefficients. This involves finding a particular solution and then adding it to the general solution of the homogeneous equation.
First, let's find the particular solution. Since the right-hand side of the equation is a polynomial, we can assume a particular solution of the form v(x) = Cx^2 + Dx + E. Plugging this into the equation, we get:
2C + ë^2(Cx^2 + Dx + E) = [-WL/(2EI)]x + [W/(2EI)]x^2
(2C + ë^2Cx^2) + (ë^2Dx) + (2C + ë^2E) = [-WL/(2EI)]x + [W/(2EI)]x^2
Comparing coefficients, we get:
2C + ë^2C = [W/(2EI)]
ë^2D = [-WL/(2EI)]
2C + ë^2E = 0
Solving for C, D, and E, we get:
C = W/(2ë^2EI)
D = -WL/(2ë^4EI)
E = -W/(4ë^2EI)
Therefore, the particular solution is v(x) = (W/2ë^2EI)x^2 - (WL/2ë^4EI)x - (W/4ë^2EI).
Next, we need to find the general solution of the homogeneous equation, which is the solution when the right-hand side of the equation is equal to 0. This can be done by solving the characteristic equation:
r^2 + ë^2 = 0
r = ±ië
Therefore, the general solution of the homogeneous equation is v(x) = Acos(ëx) + Bsin(ëx), where A and B are constants.
Finally, the general solution of the original equation is the sum of the particular solution and the general solution of the homogeneous equation:
