How does SR work at speeds greater than c?
  • Context: Graduate
  • Thread starter Thread starter aychamo
    Sr Work
The discussion explores the implications of special relativity (SR) when considering hypothetical scenarios involving travel at speeds greater than the speed of light (c). Participants engage with theoretical concepts, mathematical formulations, and speculative ideas related to time dilation and warp drives, while acknowledging the science fiction nature of the topic.
  • One participant questions whether special relativity holds if an object were to travel at multiples of c, speculating on the effects of time dilation at such speeds.
  • Another participant introduces the Lorentzian transformation equations, noting that substituting a velocity greater than c leads to imaginary numbers, suggesting a breakdown of the conventional understanding of time dilation.
  • A participant expresses disappointment that time dilation cannot be explored with speeds greater than c within the context of special relativity.
  • Another participant proposes a modification of Alcubierre's spacetime, suggesting that it may allow for the manipulation of spacetime geometry to achieve effects similar to those of traveling faster than light.
  • Discussion includes references to the Alcubierre warp drive and its implications for time dilation, with participants acknowledging the complexity of the mathematical expressions involved.
Participants express differing views on the implications of traveling faster than c, with some suggesting that conventional SR cannot be applied, while others explore alternative theoretical frameworks. The discussion remains unresolved regarding the feasibility and implications of such speeds.
Limitations include the speculative nature of faster-than-light travel and the reliance on hypothetical constructs like the Alcubierre warp drive. The mathematical steps and assumptions underlying the proposed modifications to spacetime geometry are not fully resolved.
aychamo
Does SR work/holdup if something were to travel at multiples, instead of fractions, of c?
For example, if you travel at .865c for 1 hour, you age one hour, while everyone else on Earth ages 2 hours. But if you travel at 10c for 1 hour, you age one hour but everyone on Earth ages .. I don't know the math :) But I'm sure it's somewhere around 10 hours?
Obviously this is science fiction, but it is fun to talk about nonetheless.
Continuing, in Star Trek we learned that people in the future wear spandex uniforms and that they can travel at warp speeds, which are, I presume, great multiples of C.
So if you were to travel a great distance at a warp speed, but in a very short amount of time, what would the effects be? On initial thought, it seems that if you travel for any significant amount of time at a huge multiple of c then anywhere you go will be so greatly aged by the time you get there that your trip there would be pointless.
When I think of this in my head, I see it as the guy who took Einstein's equations and used them to think up black holes, although that was an original thought and I'm sure what I'm writing about has been covered before somewhere else.
So does calculating the gamma factor, with the 1/sqrt(..whatever) equation hold up when using multiples of c, instead of fractions? If I wanted to put in some figures to test my ideas with different values in the above paragraph, what simple equations could I use?
Thank you
Aychamo
The easiest equation (That I know of) to see the relativistic effects of high velocities are the Lorentzian transformation equations, specific to your question the equation for Time Dilation:
where v = your velocity,
c = speed of light.
(Picture from Wolfram's Science world)
So you want to know what happens when v > c eh? Let's c:
The First thing we do to simplify is make up a new scale, we are going to say that c = 1. (so we don't have to deal with really big numbers, the actual numbers we get don't really matter, just relations)
Lets also say that v = 2c, in this example you will be traveling at twice the speed of light.
Lets plugin:
= 1 / Sqrt(1 - v^2) -> The modified equation with c = 1
= 1 / Sqrt(1 - 4) -> 2 squared = 4
= 1 / Sqrt(-3) -> Ding Ding Ding, your mathy sense should be tingling, you can't get a regular answer when you have a negative number under a root sign (try it on a calculator), to deal with this, mathematicians invented the concept of imaginary numbers (i = Sqrt(-1)), so given that this equation is for time dilation, what you are dealing with here is some sort of freaky deaky imaginary time (Star trek would be proud),
So in conclusion, when you plug any number greater than c (1 in our system of units) into the Lorentzian equation of time dilation you get an imaginary answer, less than c and you get good ol' relativistic modifications, and at c itself you get Sqrt(0)!
Although this is all quite exciting, you really shouldn't start comparing yourself to Schwarzschild (Found the first solution set to Einstein's field equations -> Black Hole), but you're well on your way to follow in his path :)
Hope I've been helpful!
Ultan
Hey man!
Good answer! That kinda sucks there is no way to play around with time dilation with regards to speeds greater than c!
Thank you though,
Aychamo
Originally posted by aychamo
Hey man!
Thank you though,
Aychamo
There is, just not within the context of "special" relativity. Consider the following modification of Alcubierre's spacetime where a ship has the hypothetical ability to modify the surrounding spacetime geometry. Let's say that the interval for the ship frame will be
[tex]ds^2 = (A^2 - \beta ^{2}g^{2})dct^2 - 2\beta gdctdz - dz^2 -dr^2 - r^{2}d\phi ^2[/tex]
were A will be 1 in the ship and a constant far from it, and g will be zero in the ship and 1 far from it. [tex]\beta[/tex] respresents v/c that the ship crew observe remote stars to be passing by and A is a time lapse function similar to the special relativistic [tex]\gamma[/tex]. What you choose the far value of A to be determines the time dilation and a combination of the bahaviors of A and g determine the matter requirements to form the modified spacetime geometry.
aychamo, glad I could help!
DW, interesting... I have to admit I've never heard of Alcubierre's spacetime!
Ultan
Ultan
In all seriousness its called the Alcubierre warp drive spacetime. The expression I wrote is a sleight modification of his. The difference being that he wrote it for a remote observer's coordinates and inserted a lapse function into the expression for with those coordinates whereas the expression I wrote is the expression for the ship frame coodinates with the lapse function inserted into the expression for with those coordinates. With a lapse function not globally 1, the one expression isn't a mere frame transformation of the other.
  • · Replies 35 ·
  • · Replies 29 ·
  • · Replies 18 ·
  • · Replies 40 ·
  • · Replies 34 ·
  • · Replies 56 ·
