Register to reply
Resonance, find the lengths
by endeavor
Tags: lengths, resonance
Share this thread:
endeavor
#1
May2-06, 10:00 PM
P: 176
"A tuning fork with a frequency of 440 Hz is held above a resonance tube partially filled with water. Assuming that the speed of sound in air is 342 m/s, for what heights of the air column will resonances occur?"
f1 = 440 Hz
v = 342m/s
I'm not sure if this is refering to an open pipe, or a closed pipe.
For an open pipe,
fn = (nv)/(2L) = nf1
v/(2L) = f1
L = v/(2f1)
L = 0.3886 m
But this is the length for the sound traveling up and down... i think. So the length is 0.194m. However, the answer gives 3 values, 0.194m, 0.583m, 0.972m. Even for a closed pipe, I there is only 1 value...
I must be doing something wrong. I don't think the speed of sound in water is a factor, because my first answer seems to be correct...
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
Andrew Mason
#2
May2-06, 11:37 PM
Sci Advisor
HW Helper
P: 6,654
Quote Quote by endeavor
f1 = 440 Hz
v = 342m/s
This is a closed pipe. There is a node at the bottom and an anti-node at the open end. So resonances occur where the length of the pipe is [itex]L = \lambda/4, 3\lambda/4, 5\lambda/4,... (2n+1)\lambda/4[/itex]
Using the universal wave equation:
[tex]\lambda = v/f [/tex]
Substituting the resonance criterion: [itex]\lambda = 4L/(2n+1) = v/f[/itex]
resonance occurs at:
[tex]L = (2n+1)v/4f = (2n+1)*342/4*440 = (2n+1).194 m.[/tex]
AM
endeavor
#3
May3-06, 12:43 AM
P: 176
Quote Quote by Andrew Mason
AM
That makes sense, except for why f is kept as the initial frequency. The formula I have is:
L = (mv)/(4fm) where m = 1,3,5,.....
and
fm = mf1
thus
L = v/(4f1)
why do I use only the initial frequency here?
Andrew Mason
#4
May3-06, 07:26 AM
Sci Advisor
HW Helper
P: 6,654
and
fm = mf1
thus
L = v/(4f1)
In this case, there is a tuning fork which provides only the fundamental frequency - a pure sine wave. There are no higher frequencies to resonate in the air column. So you are dealing with the fundamental frequency only.
AM
endeavor
#5
May3-06, 12:58 PM
P: 176
AM
Oh, Ok. Thanks!
Register to reply
Related Discussions
HELP:where can I find data for schumann resonance? General Physics 0
Focal Lengths Introductory Physics Homework 1
Resonance: harmonic resonance Introductory Physics Homework 2
Find force of wires with different lengths Introductory Physics Homework 0
