Thread Closed
Quantum Gravitation...
Share Thread Thread Tools
Jan3-04, 03:51 AM   #1
Quantum Gravitation String Theory:
Planck's Radius:
[tex]r_p = \sqrt{ \frac{ \hbar G}{ c^3}}[/tex]
Minimum observable length for a quantum string:
[tex]r_m = 2 \sqrt{ \alpha '}[/tex]
Planck's Radius is minimum observable length for a quantum string:
[tex]r_p = r_m[/tex]
Planck area of the hyperspace amplified Salam G* strong short range low energy gravity.
[tex]\sqrt{ \frac{ \hbar G}{ c^3}} = 2 \sqrt{ \alpha ^'}[/tex]
Alpha Prime:
[tex]\alpha ' = \frac{ \hbar G}{ 4 c^3}[/tex]
Alpha Prime is constant for a Planck Scale Bosonic String.
String Tension:
[tex]T_s = \frac{ 1}{2 \pi \alpha '}[/tex]
Quantum Gravitation String Tension:
[tex]T_g = \frac{ 2 c^3}{ \pi \hbar G}[/tex]
Relationship between distance and momentum:
[tex]\Delta L = \frac{ \hbar}{ p} + \alpha ' \frac{ p}{ \hbar}[/tex]
Quantum Gravitation distance and momentum:
[tex]\Delta L = \frac{ \hbar}{ p} + \frac{ G p}{4 c^3}[/tex]
Bosonic and fermionic hadronic Regge trajectory resonance:
[tex]J = \alpha ' E^2[/tex]
[tex]J = \frac{ \hbar G}{ 4 c^3} E^2[/tex]
[tex]E = \sqrt{ \frac{ 4 J c^3}{ \hbar G}}[/tex]
Reference:
http://superstringtheory.com/basics/basic3a.html
http://www.lepp.cornell.edu/spr/2001-05/msg0032717.html
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Jan4-04, 06:18 AM   #2
Nice summary of formulas. Your second formula is problematic because it means that in superstring theory there's a minimum distance that you can measure, the distance given by the formula. Alpha prime is also called Regge slope
Your fifth formula, the formula that you give for alpha prime is incorrect. Alpha prime is not a constant
Thread Closed
Thread Tools
Similar Threads for: Quantum Gravitation...
Thread Forum Replies
Cleaner quantum gravitation? General Physics 5
reversing quantum time and effects it has on existing particles within quantum field? General Discussion 0
