Understanding Circular Motion: Force and Velocity in Orbits Explained"
  • Thread starter Thread starter allok
    Confusing
The discussion revolves around the concepts of circular motion and gravitational forces, particularly focusing on how these forces affect the velocity of an object in orbit around the Earth. Participants are exploring the relationship between the direction of gravitational force and the velocity of orbiting objects, questioning the implications of perpendicular forces in circular versus elliptical orbits.
  • Participants are examining the assertion that a perpendicular force only changes the direction of velocity, questioning its validity in the context of both circular and elliptical orbits. They discuss the components of velocity and gravitational force, considering how these components interact at different points in an orbit.
The conversation is ongoing, with participants providing insights and challenging assumptions. Some have offered clarifications regarding circular versus elliptical orbits, while others have pointed out perceived flaws in specific statements made by the original poster. There is a mix of interpretations being explored without a clear consensus.
Participants are navigating the complexities of gravitational forces in different orbital shapes, noting that assumptions about perpendicularity may not hold in all cases, particularly in elliptical orbits. The discussion reflects a range of understandings and interpretations of the physics involved.
allok
hiya
Circular motion is really confusing
Force perpendicular to velocity is said to change only velocity's direction but not its magnitude. But how about object orbiting the earth? If object orbits the Earth then force of gravity is perpendicular to it and thus is said it only changes its direction.
Ok, so perpendicular force only can change direction of velocity because it doesn't have any components parallel to velocity. But:
if you break velocity vector of an orbiting object in components ( at any point on its path ) and also break force of gravity into components, then it becomes obvious that force of gravity always has component parallel to some comonent of object's velocity vector and as such it never really is perpendicular to velocity.
I need a little help people
thank you
allok said:
hiya
thank you
If the orbit is circular, the force of gravity will always be perpendicular to the velocity. Pick any point of the orbit. The velocity is tangent to the circle along which the object is moving, right? And the force of gravity is always toward the center of the Earth. You can convince yourself that the force will always be perpendicular to the velocity and therefore the speed (the magnitude of the velocity) does not change.
If the orbit is elliptical, then yes, there are some points where the force is not perpendicular to the velocity and in that case the speed is not constant (in agreement with Kepler's second law of planetary motion)
allok said:
hiya
ONLY if the orbit is a circle. Most orbits are somewhat elliptical. Force is perpendicular to velocity only at the ends - where the ellipse intersects the major axis.
In an elliptical orbit the central force DOES change the magnitude of velocity because it is not always perpendicular to the velocity.
AM
allok said:
hiya
But:
Make the X-axis in the direction of the speed and the y-axis in the direction of the gravity. You will see that they don't cancel each other out. And even if you choose different coords, you'll get the same resault cause all the gravity components in the direction of the velocity will cancel out.
"If object orbits the Earth then force of gravity is perpendicular to it and thus is said it only changes its direction."
It is this sentence by you which is flawed; the rest is well thought out.
  • · Replies 35 ·
  • · Replies 31 ·
