Treating parallel electromagnets as current carrying wires.
The original poster attempts to understand whether two parallel electromagnets can be treated as current-carrying wires to determine the strength of the magnetic field, particularly in the context of dampening vibrations of a metal sheet placed between them.
  • Participants discuss the appropriateness of applying equations typically used for current-carrying wires to the scenario involving electromagnets. Some question the assumptions behind this approach.
The discussion has not reached a consensus, with participants exploring different interpretations of the original question and the implications of the setup. There is an ongoing dialogue about the nature of the problem and the relevance of the proposed method.
There is a suggestion that the original poster's choice of username may affect the seriousness with which their question is received, although this does not directly relate to the technical aspects of the inquiry.
daffodildo
Right I'm doing a piece of work that needs a simple question answering.
If you had two parallel electromagnets, between them a metal sheet that is being constantly vibrated with the electromagnets being used to dampen these vibrations, can you treat them as two current-carrying wires and use the equation* to determine the strength of the magnetic field?
*http://img455.imageshack.us/img455/2038/img510kr.gif
Thanks.
Why don't you change your new PF sign-in handle and try asking the question again? You'll get treated a lot more seriously here with a reasonable handle.
daffodildo at birth, daffodildo at death.
Pffft, this is racism, just in a different form.
We have no control over our race, hence racism is bad. We *do* have control over what handle we choose, and maybe a little thought on your part will result in a more appropriate handle for a technical forum like PF. Daffodildo is probably a pretty catchy handle for chat rooms and such, but PF is about technical information sharing. It's up to you, but I'd recommend a change. Like I said, you'll probably get a fair amount more help and be taken more seriously with a more appropriate handle for this website. My two cents. -Mike-
Bit harsh isn't it mate? I mean if he wants a daft name, that's his choice :-p
~H
~H
Well, I guess you're right. And don't get me wrong, I have nothing against dildos. In the proper, er, hands, they can be a wonderful tool. :rolleyes: But they're just not what I generally have on my mind when I stop by the good old PF. Whatever. Fire away Daffod..., er, I mean ask away!
So many puns in there, I don't know where to start. :biggrin:
~H
