A very quick query about strain gauges
  • Context: Undergrad
  • Thread starter Thread starter $id
    Strain
The discussion centers on the use of strain gauges in a half-Wheatstone bridge configuration to measure weight. The user seeks clarification on the relationship between resistance changes in the strain gauges and the resulting voltage readings. It is established that bending the gauges will create a resistance difference, which translates to a voltage change across the bridge. Additionally, the user inquires whether increasing the bending will yield a larger voltage reading, confirming the direct correlation between strain and voltage output.
  • Understanding of Wheatstone bridge circuits
  • Knowledge of strain gauge operation and characteristics
  • Basic principles of voltage measurement
  • Familiarity with resistance and its effect on electrical circuits
  • Research Wheatstone bridge calibration techniques
  • Learn about strain gauge types and their specifications
  • Explore voltage measurement methods in bridge circuits
  • Investigate the effects of temperature on strain gauge readings
Engineers, researchers, and students involved in mechanical testing, sensor technology, and electrical engineering who are working with strain gauges and Wheatstone bridge circuits.
$id
I am doing a project on strain gauges. I have the thing set up in a half-wheatstone bridge. Using a pair of strain gauges I am trying to measure the weight!(attaching each one to a side of a ruler/cantilever and bending it by attaching weight to the end)
So here's a confusing bit. I no when the gauges are unstrained the reading on the bridge shud be ZERO(i.e bridge is balanced) I'm measuring the voltage difference across the bridge not current. The point is when i bend them i get a reading(which i shud)
Am i correct in assuming that the resistance difference across the bridge when i bend it. This will b recorded as a voltage change?
SO here's a question. If i bend it more the resistance difference should b greater so should i get a bigger reading (voltmeter) on the scales or not??
I no the explanation isn't a perfect . PLease bear with me.
What voltage are you measuring?
If I recall correctly a Wheatstone bridge relies on current measurements. If one arm is out of balance, a current will flow through the center, you then adjust the resistance in the arm opposite the load to zero the current.
You may want to check into a spell checker, while it is possible to figure out what you are trying to say, frequently I will simply go to the next message rather then attempt to figure out something as poorly written as your message.
  • · Replies 77 ·
  • · Replies 19 ·
