Constant liquid pressure device
The discussion revolves around creating a constant head device to measure the velocity of a water stream in relation to its cross-sectional area. The original poster seeks guidance on constructing such a device using basic tools at home.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster considers using a bucket with one inlet and two outlets to maintain constant pressure but is uncertain about its effectiveness. They also mention a method for measuring the stream's cross-sectional area using shadows, though they encounter issues with shadow clarity.
  • Some participants suggest using a bucket filled with water and a hose to ensure a constant head, while others propose using a lens to measure the stream's diameter through image magnification.
The discussion is ongoing, with various approaches being explored. Participants have provided suggestions for maintaining constant pressure and measuring the stream's diameter, but no consensus has been reached on the best method to achieve the original poster's goals.
The original poster is working with limited resources and is looking for practical solutions that can be implemented at home. There are challenges related to measuring the stream's cross-sectional area accurately.
justrezza
I was wondering if anyone could point me towards a source about making constant head devices. I was wanting to measure and then relate, experimentally, the velocity of a stream to its cross-sectional area. Since this will be done mostly at home using pedestrian tools, I need to find out how I can make a device to allow me to have constant pressure for my stream.
I was thinking of a bucket with one inlet and two outlets, but I'm not quite sure if that would work.
Thanks for your help
An addendum. I intend to measure the cross sectional area of the stream using the shadows it casts on a surface, since measuring the stream diameter would be very hard.
However, here I encounter another problem, the shadows become indistinct as I cast them on the wall, and are useless to my measurements.
You should be able to use a bucket to create a stream with constant head. Just fill the bucket up and put a running hose in it. Then you can have a tube coming out the bottom and as long as there is more water going into the bucket than coming out (ie. the bucket is overflowing or at least staying at the same level) you will have a source of water at constant head.
You can use a lens to form an image of the stream and then measure the diameter on the image. Use the magnification to convert this to the real diameter. If you work at 2f for both image and object distance the magnification is x1.
  • · Replies 20 ·
